Rename value is not working
Hi All, I’m using influxDb v2 and I can’t rename a value to a friendly one:
The filter is: |> filter(fn: (r) => r["_field"] == “ifInBits_rate” or r["_field"] == “ifOutOctets_rate”)
I tried the following map but it did not work:
|> map(fn: (r) => ({
r with name:
if r._field == “ifInBits_rate” then “In Bits”
else “Out Bits”
Any ideas?
Hi, try this map command:
|> map(fn: (r) => ({ r with _field: if r._field == “ifInBits_rate” then “In Bits” else “Out Bits” }) )
You have to specify the column name which needs to be replaced, in your case the _field column.
Best regards
It worked. Thanks a lot for the quick response
