I would like to rename column after my query, the extract of my query works well if all the columns exist.
Depending the time range selection, it can be possible that one or more field don’t exist.
When a field does not exist I got the error message
runtime error @23:8-23:43: rename: rename error: column “HCHC” doesn’t exist
Is it possible to do rename only if the column exists ?
I do not find syntax to do it
Thanks in advance
max =
data()
|> aggregateWindow(every: 1d, fn: max, createEmpty: false)
//|> fill(value: 0.0)
|> pivot(rowKey:["_time"], columnKey: ["_measurement"], valueColumn: "_value")
|> rename(columns: {HCHC: "HCHC_Max"})
|> rename(columns: {HCHP: "HCHP_Max"})
|> rename(columns: {BBRHCJB: "BBRHCJB_Max"})
|> rename(columns: {BBRHCJW: "BBRHCJW_Max"})
|> rename(columns: {BBRHCJR: "BBRHCJR_Max"})
|> rename(columns: {BBRHPJB: "BBRHPJB_Max"})
|> rename(columns: {BBRHPJW: "BBRHPJW_Max"})
|> rename(columns: {BBRHPJR: "BBRHPJR_Max"})
join(tables: {min: min, max: max}, on: ["_time"])
|> drop(columns: ["_field_max","_field_min","_start_max","_start_min","_stop_max","_stop_min"])
