mpaul
December 6, 2017, 10:12pm
1
Trying to do remote backup but its not working out!
Do we need to provide auth credentials for the remote influxdb instance ?
what am i missing … any help appreciated!
command used
/usr/bin/influxd backup -database myremoteDB -host <MYIP?:8088 /opt/influxdb/backups/remote_backup_influx_dbs/myremotehost/06Dec2017/myremoteDB
2017/12/06 22:14:12 backing up db=myremoteDB since 0001-01-01 00:00:00 +0000 UTC
2017/12/06 22:14:12 backup failed: dial tcp IP.IP.IP.IP:8088: getsockopt: connection refused
backup: dial tcp <IP>:8088: getsockopt: connection refused
actual backup on remotehost :
myremotehost:/opt/influxdb/backups/backup_influx_dbs/06Dec2017/mydb $ ll
total 993984
-rw-r--r-- 1 influxdb influxdb 34131 Dec 6 21:52 meta.00
-rw-r--r-- 1 influxdb influxdb 82073088 Dec 6 21:52 mydb.autogen.03933.00
-rw-r--r-- 1 influxdb influxdb 78328320 Dec 6 21:52 mydb.autogen.03962.00
-rw-r--r-- 1 influxdb influxdb 78999040 Dec 6 21:52 mydb.autogen.03991.00
-rw-r--r-- 1 influxdb influxdb 30470144 Dec 6 21:52 mydb.autogen.04020.00
-rw-r--r-- 1 influxdb influxdb 28937216 Dec 6 21:52 mydb.autogen.04049.00
-rw-r--r-- 1 influxdb influxdb 82207744 Dec 6 21:52 mydb.autogen.04078.00
-rw-r--r-- 1 influxdb influxdb 82966528 Dec 6 21:52 mydb.autogen.04107.00
-rw-r--r-- 1 influxdb influxdb 83372544 Dec 6 21:52 mydb.autogen.04136.00
-rw-r--r-- 1 influxdb influxdb 83589632 Dec 6 21:52 mydb.autogen.04165.00
-rw-r--r-- 1 influxdb influxdb 83168768 Dec 6 21:52 mydb.autogen.04194.00
-rw-r--r-- 1 influxdb influxdb 20535296 Dec 6 21:52 mydb.autogen.04223.00
-rw-r--r-- 1 influxdb influxdb 28866048 Dec 6 21:52 mydb.autogen.04252.00
-rw-r--r-- 1 influxdb influxdb 81377280 Dec 6 21:52 mydb.autogen.04281.00
-rw-r--r-- 1 influxdb influxdb 82700288 Dec 6 21:52 mydb.autogen.04310.00
-rw-r--r-- 1 influxdb influxdb 90182656 Dec 6 21:52 mydb.autogen.04339.00
mpaul
December 6, 2017, 10:56pm
2
thought it has to do with the “bind-address” could not even find one !
/etc/influxdb $ grep bind-address influxdb.conf
bind-address = ":8083"
# bind-address = ":8086"
# bind-address = ":2003"
# bind-address = ":25826"
# bind-address = ":4242"
# bind-address = ":8089"
so under which section is really the remote RPC port configured my influxdb version : 1.4.2
any sample will help !
mpaul
December 6, 2017, 11:34pm
3
Tried putting
activate RPC port !
bind-address = “127.0.0.1:8088”
before and after the [meta] section still same error :
backup: dial tcp :8088: getsockopt: connection refused
mpaul
December 7, 2017, 4:35pm
4
when I run it netstat -nlpt it doies show influxdb is listening on that port !
netstat -nlpt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 2298/influxd
tcp 0 0 :::8086 :::* LISTEN 2298/influxd
mpaul
December 7, 2017, 4:47pm
5
Solved the riddle
I wish the influxdb documentation is a better on this,
the activate RPC port should be !
# activate RPC port !
#bind-address = "127.0.0.1:8088"
bind-address = ":8088"
Local host will not be able to let remote backup connections work !
now the remote backups are working perfectly!
Are you also providing authentication?
mpaul
December 11, 2017, 7:35pm
7
I did not find a good documentation about RPC authentication , my servers do need auth but RPC works without it …
May be some one from Engg can help here with how to ! ( I am trying to make myself believe tick data is not critical security info so works ! )
For remote backups we recommend restricting access to the port at the OS or network level.
From the InfluxDB > Administration > Security Best Practices documentation:
InfluxDB uses port 8088 for remote backups and restores. We highly recommend closing that port and, if performing a remote backup, giving specific permission only to the remote machine.
If you just open that port to 0.0.0.0, anyone can get your data (by doing a backup) and anyone can overwrite your data (by doing a restore). I would limit it to 127.0.0.1 and use a ssh tunnel to connect.
mpaul
December 11, 2017, 9:59pm
10
Checking with network admin , how to grant perms to specific hosts to connect to port 8088 running on localhost!
I seems that all the ssh tunneling and firewalls are pretty kludge for a database infrastructure!
I seems that the best possible solution would be influxdb to support login/password on the RPC port so we can use this port for setting up manual DR !
