New to InfluxDB but familiar with TSDBs like OSI PI and Wonderware Historian.
Running some performance tests on InfluxDB with 5 tags that produce data points (numbers) every 1 second. Currently have roughly 500,000 points in the database over 2 day period. I am finding that the queries are slower than what I would expect for a small number of data points.It seems to take several minutes to retrieve ~500k points from the database (raw data query). Is there anything that can be done to improve this retrieval time for the raw data?
Note: The queries do get slightly better when I run functions with longer time intervals like “Group By time(10s)”. However, with such a small data set I would expect the raw data retrieval times to be much faster for ~500k points of data.
My schema is very simple:
Measurement: PLC
Tags: tagname, quality
Fields: value
Environment is running on Raspberry PI 3B+. Memory is good during performance test (well within the memory of unit). CPU fluctuates depending on read query and will max out periodically to 100%, but return to normal. Data store will be on the SD card on the unit.
Many thanks in advance for any insight you can bring to improving this performance.
