I’m having a 42 minutes delay when wirting form influxdb to grafana on a raspberry pi. I have tried different setting but nothing is working for me.
Thanks for the help.
This is what it looks to me on grafana.
This is my influxdb.config
### Welcome to the InfluxDB configuration file.
# Once every 24 hours InfluxDB will report anonymous data to m.influxdb.com
# The data includes raft id (random 8 bytes), os, arch, version, and metadata.
# We don't track ip addresses of servers reporting. This is only used
# to track the number of instances running and the versions, which
# is very helpful for us.
# Change this option to true to disable reporting.
reporting-disabled = false
### [meta]
### Controls the parameters for the Raft consensus group that stores metadata
### about the InfluxDB cluster.
[meta]
dir = "/var/lib/influxdb/meta"
hostname = "localhost"
bind-address = ":8088"
retention-autocreate = true
election-timeout = "1s"
heartbeat-timeout = "1s"
leader-lease-timeout = "500ms"
commit-timeout = "50ms"
cluster-tracing = false
# If enabled, when a Raft cluster loses a peer due to a `DROP SERVER` command,
# the leader will automatically ask a non-raft peer node to promote to a raft
# peer. This only happens if there is a non-raft peer node available to promote.
# This setting only affects the local node, so to ensure if operates correctly, be sure to set
# it in the config of every node.
# raft-promotion-enabled = true
### [data]
### Controls where the actual shard data for InfluxDB lives and how it is
### flushed from the WAL. "dir" may need to be changed to a suitable place
### for your system, but the WAL settings are an advanced configuration. The
### defaults should work for most systems.
[data]
dir = "/var/lib/influxdb/data"
# Controls the storage engine used for new shards. Engines available are b1,
# bz1, and tsm1. b1 was the original default engine from 0.9.0 to 0.9.2. bz1
# has been the default engine since 0.9.3. tsm1 was introduced in 0.9.5 and is
# currently EXPERIMENTAL. Consequently, data written into the tsm1 engine may
# need to be wiped between upgrades.
engine ="tsm1"
# The following WAL settings are for the b1 storage engine used in 0.9.2. They won't
# apply to any new shards created after upgrading to a version > 0.9.3.
# max-wal-size = 104857600
# max-wal-size = 104857600 # Maximum size the WAL can reach before a flush. Defaults to 100MB.
# wal-flush-interval = "10m0s" # Maximum time data can sit in WAL before a flush.
# wal-partition-flush-delay = "2s" # The delay time between each WAL partition being flushed.
# These are the WAL settings for the storage engine >= 0.9.3
wal-dir = "/var/lib/influxdb/wal"
wal-logging-enabled = true
data-logging-enabled = false
# When a series in the WAL in-memory cache reaches this size in bytes it is marked as ready to
# flush to the index
# wal-ready-series-size = 25600
# Flush and compact a partition once this ratio of series are over the ready size
# wal-compaction-threshold = 0.6
# Force a flush and compaction if any series in a partition gets above this size in bytes
# wal-max-series-size = 2097152
# Force a flush of all series and full compaction if there have been no writes in this
# amount of time. This is useful for ensuring that shards that are cold for writes don't
# keep a bunch of data cached in memory and in the WAL.
# wal-flush-cold-interval = "10m"
# Force a partition to flush its largest series if it reaches this approximate size in
# bytes. Remember there are 5 partitions so you'll need at least 5x this amount of memory.
# The more memory you have, the bigger this can be.
# wal-partition-size-threshold = 20971520
# Whether queries should be logged before execution. Very useful for troubleshooting, but will
# log any sensitive data contained within a query.
query-log-enabled = false
# Settings for the TSM engine
# CacheMaxMemorySize is the maximum size a shard's cache can
# reach before it starts rejecting writes.
cache-max-memory-size = 524288000
# CacheSnapshotMemorySize is the size at which the engine will
# snapshot the cache and write it to a TSM file, freeing up memory
cache-snapshot-memory-size = 26214400
# CacheSnapshotWriteColdDuration is the length of time at
# which the engine will snapshot the cache and write it to
# a new TSM file if the shard hasn't received writes or deletes
cache-snapshot-write-cold-duration = "1h"
# MinCompactionFileCount is the minimum number of TSM files
# that need to exist before a compaction cycle will run
compact-min-file-count = 3
# CompactFullWriteColdDuration is the duration at which the engine
# will compact all TSM files in a shard if it hasn't received a
# write or delete
compact-full-write-cold-duration = "24h"
# MaxPointsPerBlock is the maximum number of points in an encoded
# block in a TSM file. Larger numbers may yield better compression
# but could incur a performance peanalty when querying
max-points-per-block = 0
### [hinted-handoff]
### Controls the hinted handoff feature, which allows nodes to temporarily
### store queued data when one node of a cluster is down for a short period
### of time.
[hinted-handoff]
# enabled = true
# dir = "/var/lib/influxdb/hh"
# max-size = 1073741824
# max-age = "168h"
# retry-rate-limit = 0
# Hinted handoff will start retrying writes to down nodes at a rate of once per second.
# If any error occurs, it will backoff in an exponential manner, until the interval
# reaches retry-max-interval. Once writes to all nodes are successfully completed the
# interval will reset to retry-interval.
# retry-interval = "1s"
# retry-max-interval = "1m"
# Interval between running checks for data that should be purged. Data is purged from
# hinted-handoff queues for two reasons. 1) The data is older than the max age, or
# 2) the target node has been dropped from the cluster. Data is never dropped until
# it has reached max-age however, for a dropped node or not.
# purge-interval = "1h"
### [cluster]
### Controls non-Raft cluster behavior, which generally includes how data is
### shared across shards.
[cluster]
# shard-writer-timeout = "5s" # The time within which a remote shard must respond to a write request.
# write-timeout = "10s" # The time within which a write request must complete on the cluster.
### [retention]
### Controls the enforcement of retention policies for evicting old data.
[retention]
enabled = true
check-interval = "10m"
advanced-period = "30m"
### [shard-precreation]
### Controls the precreation of shards, so they are available before data arrives.
### Only shards that, after creation, will have both a start- and end-time in the
### future, will ever be created. Shards are never precreated that would be wholly
### or partially in the past.
[shard-precreation]
enabled = true
check-interval = "5m"
advance-period = "10m"
### Controls the system self-monitoring, statistics and diagnostics.
### The internal database for monitoring data is created automatically if
### if it does not already exist. The target retention within this database
### is called 'monitor' and is also created with a retention period of 7 days
### and a replication factor of 1, if it does not exist. In all cases the
### this retention policy is configured as the default for the database.
[monitor]
# store-enabled = true # Whether to record statistics internally.
# store-database = "_internal" # The destination database for recorded statistics
# store-interval = "10s" # The interval at which to record statistics
### [admin]
### Controls the availability of the built-in, web-based admin interface. If HTTPS is
### enabled for the admin interface, HTTPS must also be enabled on the [http] service.
[admin]
enabled = true
bind-address = ":8083"
https-enabled = false
https-certificate = "/etc/ssl/influxdb.pem"
### [http]
### Controls how the HTTP endpoints are configured. These are the primary
### mechanism for getting data into and out of InfluxDB.
[http]
enabled = true
bind-address = ":8086"
auth-enabled = false
log-enabled = false
write-tracing = false
pprof-enabled = false
### [[graphite]]
### Controls one or many listeners for Graphite data.
[[graphite]]
enabled = false
# database = "graphite"
# bind-address = ":2003"
# protocol = "tcp"
# consistency-level = "one"
# name-separator = "."
# These next lines control how batching works. You should have this enabled
# otherwise you could get dropped metrics or poor performance. Batching
# will buffer points in memory if you have many coming in.
# batch-size = 1000 # will flush if this many points get buffered
# batch-pending = 5 # number of batches that may be pending in memory
# batch-timeout = "1s" # will flush at least this often even if we haven't hit buffer limit
# udp-read-buffer = 0 # UDP Read buffer size, 0 means OS default. UDP listener will fail if set above OS max.
## "name-schema" configures tag names for parsing the metric name from graphite protocol;
## separated by `name-separator`.
## The "measurement" tag is special and the corresponding field will become
## the name of the metric.
## e.g. "type.host.measurement.device" will parse "server.localhost.cpu.cpu0" as
## measurement: "cpu",
## tags: {
## "type": "server",
## "host": "localhost,
## "device": "cpu0"
# name-schema = "type.host.measurement.device"
## If set to true, when the input metric name has more fields than `name-schema` specified,
## the extra fields will be ignored.
## Otherwise an error will be logged and the metric rejected.
# ignore-unnamed = true
### [collectd]
### Controls the listener for collectd data.
[collectd]
enabled = false
# bind-address = ""
# database = ""
# typesdb = ""
# read-buffer = 0 # UDP Read buffer size, 0 means OS default. UDP listener will fail if set above OS max.
### [opentsdb]
### Controls the listener for OpenTSDB data.
[opentsdb]
enabled = false
# bind-address = ":4242"
# database = "opentsdb"
# retention-policy = ""
# tls-enabled = false
# certificate= ""
# log-point-errors = true # Log an error for every malformed point.
# otherwise you could get dropped metrics or poor performance. Only points
# metrics received over the telnet protocol undergo batching.
### [[udp]]
### Controls the listeners for InfluxDB line protocol data via UDP.
[[udp]]
enabled = false
# bind-address = ""
# database = "udp"
# set the expected UDP payload size; lower values tend to yield better performance, default is max UDP size 65536
# udp-payload-size = 65536
### [continuous_queries]
### Controls how continuous queries are run within InfluxDB.
log-enabled = false
# enabled = true
# run-interval = "1s" # interval for how often continuous queries will be checked if they need to run
