Ram is shooting up because of high data pump to influxdb
We are running Influxdb in k8s environment, we are pushing some 50k data to influxdb for 3 days continuously. We could see host ram is shooting up and system is getting slow.
As influxdb stores data in disk as well as ram for fast process, is there any configuration in influxdb where we can limit storation of data in ram?
I had a similar issue, the RAM was saturating due to the disk being too slow to write all the data.
As far as I know, there are no conf settings to set a limit in the RAM usage, probably because that would mean actually dropping data… which will happen anyway once the RAM fills up (as InfluxDB will refuse mew data). My suggestion is to have a look at your disks and ensure they are able to sustain the read/write load.
The only way I found to solve my problem (since I could not have better disks, and they were way below the minimum suggested IOPS) was to limit the gathered data, meaning that I avoided gathering some heavy data from the less used systems.
You can have a look at the hardware sizing suggestion here:
Hi, Thanks for your reply.
If you are familiar with influxdb internals, influxdb supports TMI for high cardianlity and we can change influxdb to use TMI. Right?
isn’t that a right solution?
I’m not that knowledgeable in InfluxDB internals, but you have 2 options
You have two options
  • TSM - Time-Structured Merge Tree
  • TSI - Time Series Index
If your problem is given by high cardinality, then TSI should help, I can’t really tell if that will solve your issue, if possible try to switch to it and see how it goes. There are people reporting that it consumes even more RAM than TSM but I think that’s up to the specific situation.
as info, I’m using TSI on all my InfluxDB instances and I had problem with it only when the disk was too slow to keep up with data fetched.
To have a more complete opinion on this one we might try to summon @Anaisdg and see if she has some more info to add about the 2 index.
Is influxdb 1.7 and later version , are by default TSI?
How can we check influxdb is with TSM or TSI?
By default it uses TSM, you can check it in the influxDB configuration file
Below is my configfile,but couldn’t able to see any info regarding that
reporting-disabled = false
bind-address = “:8088”
[meta]
dir = “/var/lib/influxdb/meta”
retention-autocreate = true
logging-enabled = true
[data]
dir = “/var/lib/influxdb/data”
wal-dir = “/var/lib/influxdb/wal”
query-log-enabled = true
cache-max-memory-size = 1073741824
cache-snapshot-memory-size = 26214400
cache-snapshot-write-cold-duration = “10m0s”
compact-full-write-cold-duration = “4h0m0s”
max-series-per-database = 1000000
max-values-per-tag = 100000
trace-logging-enabled = false
[coordinator]
write-timeout = “10s”
max-concurrent-queries = 0
query-timeout = “0s”
log-queries-after = “0s”
max-select-point = 0
max-select-series = 0
max-select-buckets = 0
[retention]
enabled = true
check-interval = “30m0s”
[shard-precreation]
enabled = true
check-interval = “10m0s”
advance-period = “30m0s”
[admin]
enabled = false
bind-address = “:8083”
https-enabled = false
https-certificate = “/etc/ssl/influxdb.pem”
[monitor]
store-enabled = true
store-database = “_internal”
store-interval = “10s”
[subscriber]
enabled = true
http-timeout = “30s”
insecure-skip-verify = false
ca-certs = “”
write-concurrency = 40
write-buffer-size = 1000
[http]
enabled = true
bind-address = “:8086”
auth-enabled = false
log-enabled = true
write-tracing = false
pprof-enabled = true
https-private-key = “”
max-row-limit = 10000
max-connection-limit = 0
shared-secret = “beetlejuicebeetlejuicebeetlejuice”
realm = “InfluxDB”
unix-socket-enabled = false
bind-socket = “/var/run/influxdb.sock”
TODO: allow multiple graphite listeners
[[graphite]]
enabled = false
bind-address = “:2003”
database = “graphite”
retention-policy = “autogen”
protocol = “tcp”
batch-size = 5000
batch-pending = 10
batch-timeout = “1s”
consistency-level = “one”
separator = “.”
udp-read-buffer = 0
TODO: allow multiple collectd listeners with templates
[[collectd]]
enabled = false
bind-address = “:25826”
database = “collectd”
batch-size = 5000
batch-pending = 10
batch-timeout = “10s”
read-buffer = 0
typesdb = “/usr/share/collectd/types.db”
security-level = “none”
auth-file = “/etc/collectd/auth_file”
TODO: allow multiple opentsdb listeners with templates
[[opentsdb]]
enabled = false
bind-address = “:4242”
database = “opentsdb”
tls-enabled = false
batch-size = 1000
batch-pending = 5
log-point-errors = true
TODO: allow multiple udp listeners with templates
[[udp]]
enabled = false
bind-address = “:8089”
database = “udp”
batch-size = 5000
batch-pending = 10
read-buffer = 0
precision = “ns”
[continuous_queries]
log-enabled = true
enabled = true
run-interval = “1s”
[logging]
format = “auto”
level = “info”
supress-logo = false
If it’s not there then it’s using the default value “inmem” (TSM)
it should be under
[data]
  index-version = "inmem"
also as far as I remember the conversion is not automatic
see this post (the part about index conversion) and maybe have a look around
After some analysis, could see memory is increasing 1g almost in a day.
We’ve a retention policy of 7d1h.
Analysis as follows :
  1. Wal file is created for each shard group, and then segment file is created(in each shard dir) when there is a write to influxdb …wal file gets appended and size increases, and When the segments hit the max segment size (10mb), they are closed and a new segment is opened.
    And tsm file will be created based on cache-snapshot-memory-size which is 26214400(26m), but seeing tsm file is creating when wal dir(_tmp files) size is 15m only. why it is happening like that?
  2. when tsm files are created and move to disk, then why in-memory size is increasing(could see wal directory not much data into that)?
hi,
one other reason for your memory that always increasing is because you define as Tag something that is always changing like a process id or net interfaces from vmware. List your tags you might find that the number is increasing every day. Tags are load in memory.
Good luck
