I have a problem with wirte to(), at the end it says: " All other columns are written to InfluxDB as tags."
Because of this my 5 added columns are saved as tags (4 of them are float values). And because tags are indexed queries take forever.
So my question is: can i save columns as fields in flux with the to() function or is there a workaround? I can only think of putting all 5 columns into a JSON String, but this would make it more complicated when i need to extract the data (or a specific “column”).
