Query specific time range and day
I want to query influx for times series with :
  • Start time at 08h00
  • end time at 19:00
    -and for a range day : Monday to Friday
Is there a way to do it ?
Regardds
Hello @Nibeckj,
Welcome.
You can create variables for those times and use the flux date package.
I’m struggling with the same problem: I want to show all data with date = current day and time 00:00 to 06:00. As I’m new to Flux I can’t figure out how to create a variable with a dynamic date and a fixed time.
In python or (other languages) I would concatenate a date string and then transform it to a date (or I would create a date and then add the hours/minutes).
In Flux I tried without any success: my_start_time = date.year(t: now()) date.month(t: now()) date.day(t: now()) (06:00:00Z)
Surely there is a simple solution … I only can’t find it (Google is not my friend today :frowning_face:).
@Anaisdg: Can you please give another hint how to combine create-variable and the date-packages?
@Nibeckj: Did you find a solution to your problem
@bjoern_b There are a few Flux functions that will help you do this:
For @Nibeckj original use case, the query would look something like:
import "date"
  |> range(start: -90d)
  |> filter(fn: (r) => r._measurement == "example-measurement")
  |> filter(fn: (r) =>
    date.weekDay(t: r._time) >= 1 and
    date.weekDay(t: r._time) <= 5
  |> hourSelection(
    start: 8,
    stop: 19,
For your use case, it would look something like:
import "date"
today = date.truncate(t: now(), unit: 1d)
  |> range(start: -90d)
  |> filter(fn: (r) => date.truncate(t: r._time, unit: 1d) == today)
  |> hourSelection(start: 0, stop: 6)
@scott That’s so great. Thanks a lot for the quick help! Such an easy solution. :+1:
Just for notice: For my final solution I combined it with a union() so that I can get a result set which spans over midnight (22:00 the day before until 06:00 the current day). Perhaps there is a smarter solution but for me it is working. :smiley:
import "date"
yesterday = date.truncate(t: -1d, unit: 1d)
bucket_yesterday = from(bucket: "telegraf")
  |> range(start: -3d)
  |> filter(fn: (r) => r["_measurement"] == "dBA")
  |> filter(fn: (r) => r["type"] == "output_to")
  |> filter(fn: (r) => r["_field"] == "value")
  |> filter(fn: (r) => date.truncate(t: r._time, unit: 1d) == yesterday)
  |> hourSelection(start: 22, stop: 23)
  |> aggregateWindow(every: 1s, fn: mean, createEmpty: false)
bucket_today = from(bucket: "telegraf")
  |> range(start: -3d)
  |> hourSelection(start: 0, stop: 5)
union(tables: [bucket_yesterday, bucket_today])
  |> yield(name: "mean")
@scott I just stumbled on a “bonus question” regarding hourSelection():
I’m live Germany. So my timezone is currently UTC+1 and in summer it’s UTC+2. hourSelection() uses (at least in my Data Explorer) UTC.
That means, if I want 22 to 6 o’clock local time:
  • Currently, during winter time, I have to set hourSelection(start: 21, stop: 23) and hourSelection(start: 0, stop: 5)
  • During summer time I would have to change the query to hourSelection(start: 20, stop: 23) and hourSelection(start: 0, stop: 4)
Is there any possibility to dynamize this behaviour so that hourSelection() uses my locale time (zone) or that I can calculate the start/stop time dynamically based on additional informations (variables, etc.)?
@bjoern_b It’s not a super elegant solution, but it should work. If you know the dates and time that the time changes, you could conditionally set variables:
import "date"
daylightSavingsStart = 2021-02-28T04:00:00Z
daylightSavingsEnd = 2021-010-31T05:00:00Z
yesterdayHourStart = if today > daylightSavingsStart and today < daylightSavingsEnd then 20 else 21
todayHourStop = if today > daylightSavingsStart and today < daylightSavingsEnd then 4 else 5
  |> range(start: -3d)
  |> hourSelection(start: yesterdayHourStart, stop: 23)
  |> range(start: -3d)
  |> hourSelection(start: 0, stop: tordayHourStop)
  |> yield(name: "mean")
I was wondering if it is possible to use these queries with the python client.
In order to try your solutions, in python I tried:
from influxdb_client import InfluxDBClient
client = InfluxDBClient(url=url, token=token, org=org)
query_api = client.query_api()
query_api.query(org=org, query = 'import "date"')
But this doesn’t work since it’s a bad request (ApiException: 400) because the Flux script returns no streaming data.
Is there any possibility to do these queries on a specific time range and day with the python client?
I’ve seen and used the:
|> hourSelection(start: 9, stop: 14)
Which is nice, but I need to filter data from, say 09:00 to 14:30. What would be my best option?
|> filter(fn: (r) =>
    if date.minute(t: r._time) >= 30 then
        if date.hour(t: r._time) > 14 then
            false
        else
        true
      else
      true
I’ve tried the above, but I can’t seem to chain the date.hour and date.minute together. They both work separately, but not together. I’m probably missing something very basic.
Thanks!
Micke
Solution to my own question: The above works in the latest version 2.5.1. Didn’t work properly in the last image I was running, I think that was 2.4.0
Still open for cleaner suggestions though, if anyone has one. :slight_smile:
I am using version 1.8 and UTC+7.
I hope it is useful to you.
import "strings"
import "experimental"
today = time(v: "${strings.substring(v: string(v: experimental.subDuration(d: 17h, from: now())), start: 0, end: 10)}T17:00:00Z" )
from(bucket: "dokiem_hatang")
  |> range(start: today )
  |> filter(fn: (r) => r._measurement == "dokiem_congsuat" and r._field == "congsuat_chia" )
  |> aggregateWindow(every: 5m, fn: mean)
  |> yield(name: "min")
Hallo Nibeckj,
Hello
i am a beginner on using influxdb. I saw your message while looking for a solution for the working days. I can’t get any further with the given answer. Can you help me get started?
Beste Regard, Maarten
I also trying to sum up data (energy consumption) between a time range using th hourSelection function.
But the code that Im using sum up the whole 24 hours. Any suggetions whats wrong with the code?
import “timezone”
option location = timezone.location(name: “Europe/Berlin”)
from(bucket: “HASS”)
|> range(start: -7d)
|> filter(fn: (r) => r[“_measurement”] == “Wh”)
|> filter(fn: (r) => r[“_field”] == “value”)
|> filter(fn: (r) => r[“domain”] == “sensor”)
|> filter(fn: (r) => r[“entity_id”] == “mqtt_haushaltsstrom_1_8_0”)
|> filter(fn: (r) => r[“friendly_name”] == “mqtt_haushaltsstrom_1_8_0”)
|> filter(fn: (r) => r[“source”] == “HA”)
|> difference()
|> aggregateWindow(every: 1d, fn: sum, timeSrc: “_start”)
