Query in Influxdb 2.0
can you please help me with this.
influx v1.7 query:
SELECT max(“Ziehkraft_IST_LIN_int”) FROM “TESTING1” WHERE (“Drehzahl_Istwert_vom_Regler” < 0.725) GROUP BY “COIL_ID”
output :
tags: COIL_ID=1
time max
1502831736010000000 109
tags: COIL_ID=2
time max
1502832704780000000 101
tags: COIL_ID=3
time max
1502833824960000000 103
tags: COIL_ID=4
time max
1502834763850000000 105
tags: COIL_ID=5
time max
1502836417140000000 108
tags: COIL_ID=6
time max
1502837445090000000 103
I want to write this in influx 2.0 but not able to write the query:
I tried this:
from(bucket: “project”)
|> filter(fn: ( r ) =>
r._measurement == “machine” and
r._field =~ /Ziehkraft_IST_LIN_int|Drehzahl_Istwert_vom_Regler/
|>pivot(rowKey:[“_time”], columnKey: [“_field”], valueColumn: “_value”)
|> filter(fn: ( r ) => r.Drehzahl_Istwert_vom_Regler < 0.725)
|> group(columns: [“coil_id”])
|>max( column:“Ziehkraft_IST_LIN_int”)
output:
but showing different result of Ziehkraft_IST_LIN_int value. Is there any mistake in using group by ?How to solve it. Please let me know.
This is the solution I found:
from(bucket: "test")
|> filter(fn: (r) =>
r._measurement == "test1" and
|> filter(fn: (r) => r.Drehzahl_Istwert_vom_Regler < 0.725)
|> group(columns: ["coil_id"])
|>max(column: "Ziehkraft_IST_LIN_int")
