I updated from 2.0 to 2.4 and the following query fails (in Grafana):
import "math"
from(bucket: "m700")
|> filter(fn: (r) => r["_field"] != "zref")
|> drop(columns: ["_start", "_stop"])
|> pivot(
rowKey:["_time"],
columnKey: ["_field"],
valueColumn: "_value"
|> map(fn: (r) => if r._measurement == "ph" then (
{ r with
orp: r.orp - 0.198 * (r.temperature - 25.0) + math.sqrt(x: 50301.0-297.0*r.temperature)
) else r )
with
recursive types not supported P != {A with orp: float}
It worked fine before, and supplying a dummy value for orp is undesirable. How can I fix this?
