Hi there,
I’m wondering if there is any way to query all tag changes over time?
I know a bit about the internal storage format of Influx and see that this will be quite an expensive operation. I don’t really mind about it, as I need to perform this operation rather seldom. I also know that I can query all different tag values by SHOW TAG KEYS and SHOW TAG VALUES, but this doesn’t fit my usecase.
In general, my question is: “At which time did the previous row had other tags then the current one?” In order to get the information, I somehow need to order all data over all time, not only per series. (My sensors can change one tag for only one day and change it back to its previous tagset afterwards. And I don’t have any control over writing data to Influx, but only reading).
Once I have the ordered data over time, I then need to iterate over all rows and detect for which row, the previous row had another tagset and thus receive my desired row “where a previous tag was different to the current one”.
Do I have to do this entire operation on my own, meaning the merging and iterating over all rows, or can I get some help from Influx in terms of writing a better query then just SELECT * FROM myMeasurement?
Once this is done, can I do the same kind of operation in Kapacitor? So for each row, I don’t really need a window of fixed time but only the previous datarow. And can this operation react on time series changes back in time accordingly? i.e. one sensor didn’t send data due to a lost internet connection => I add this data a few days later => Kapacitor script detects if and when there were tag changes compared to the previous row (Which is for one of the newly added rows a comparison to an “old” row in Influx).
I know, I speak a lot in terms of rows which is more a SQL storage then a columnar storage like Influx is, but I think, for this one problem, the problem can be described in an easier to understand way.
Best regards
