Hi
I am new here and to flux.
I tried even with chatGPT, but nothing worked for me.
I have records that value/measurement is a SHIFT number and two tags startTime and endTime which contain hours, for example:
startTime: “06:30”
endTime: “14:45”
How do I build a query to find if now() is between those hours?
Can you help?
scott
April 18, 2024, 7:45pm
2
@Michal_Augustyniak now() returns a full RFC3339 timestamp which includes day and time. Is it safe to assume that startTime and endTime refer to the current day?
Are startTime and endTime tags or fields?
startTime and endTIme are fileds, yes.
Yes, the goal is to find a current running shift in the factory based on the shift hours.
Example
startTime, endTime, shift
06:30, 14:00, 1
14:30, 22:00, 2
So I need to find out if time(now()) is between those hours.
scott
April 21, 2024, 2:19am
4
Ok, there are a few different ways you can do this. My first thought is to use string manipulation to build time values based off the startTime and endTime strings and compare them to now():
import "strings"
data
|> map(fn: (r) => {
todayString = "${today()}"
shiftStart = time(v: strings.replace(v: todayString, t: "T00:00", u: "T${r.startTime}", i: 1))
shiftEnd = time(v: strings.replace(v: todayString, t: "T00:00", u: "T${r.endTime}", i: 1))
return {r with currentShift: now() >= shiftStart and now() <= shiftEnd}
I tried, this
import “strings”
data = from(bucket: “Azure Shift Data”)
|> range(start: 0)
|> filter(fn: (r) => r[“_measurement”] == “AG-000018” and r[“_field”] == “shiftNo”)
|> group(columns: [“_value”])
|> first()
//|> yield(name: “first”)
|> map(fn: (r) => {
todayString = “${today()}”
shiftStart = time(v: strings.replace(v: todayString, t: “T00:00:00Z”, u: “T${r.startTime}”, i: 1))
shiftEnd = time(v: strings.replace(v: todayString, t: “T00:00:00Z”, u: “T${r.endTime}”, i: 1))
results
table, _measurement, _field, _value, _start, _stop, _time, currentShift, endTime, startTime
0 AG-000018 shiftNo 1 0 2024-04-21T21:26:34.960Z 2024-03-12T18:53:25.000Z false 14:00:00 6:00:00
1 AG-000018 shiftNo 2 0 2024-04-21T21:26:34.960Z 2024-03-12T18:53:25.000Z false 22:00:00 14:00:00
2 AG-000018 shiftNo 3 0 2024-04-21T21:26:34.960Z 2024-03-12T18:53:25.000Z false 6:00:00 22:00:00
When I try to see what shiftStart variable outputs, it returns this “2024-04-21T00:00:00.000Z”. So the replace() function is not working yet.
I corrected
import “strings”
|> range(start: 0)
|> first()
|> map(fn: (r) => {
shiftStart = time(v: strings.replace(v: todayString, t: “T00:00:00.000000000Z”, u: “T${r.startTime}Z”, i: 1))
shiftEnd = time(v: strings.replace(v: todayString, t: “T00:00:00.000000000Z”, u: “T${r.endTime}Z”, i: 1))
And it outputs this
1 AG-000018 shiftNo 2 0 2024-04-21T21:26:34.960Z 2024-03-12T18:53:25.000Z true 22:00:00 14:00:00
I think that is correct. I will be testing it yet
Thank you so much !!!
Hey, so I found a problem with the timezone.
I added
option location = timezone.location(name: “America/New_York”)
It looks like it does not change the now() function which gives incorrect results. I probably could subtract hours but this would not solve the daylight saving.
Any idea ?
scott
April 22, 2024, 2:58pm
8
In Flux, the location option does not update timestamps. It only adjust window boundaries across time shifts (Daylight Savings Time, British Summer Time, etc.). All timestamps stored in the _time column and returned by now() are UTC timestamps. To get your query working for your local timezone, you need to add a timezone offset to the times that get from your shift boundaries. Assuming the New York timezone:
import "strings"
data =
from(bucket: "Azure Shift Data")
|> range(start: 0)
|> filter(fn: (r) => r["_measurement"] == "AG-000018" and r["_field"] == "shiftNo")
|> group(columns: ["_value"])
|> first()
|> map(
fn: (r) => {
shiftStart = time(v: strings.replace(v: todayString, t: "T00:00:00Z", u: "T${r.startTime}:00-04:00", i: 1))
shiftEnd = time(v: strings.replace(v: todayString, t: "T00:00:00Z", u: "T${r.endTime}:00-04:00", i: 1))
You are correct, this would’t solve daylight savings. This query would have to be adjusted with a new UTC offset. I’m sure there would be a way to automate this though.
Updated query if someone is interested
import “strings”
import “date”
import “timezone”
option location = timezone.fixed(offset: -5h)
|> range(start: 0)
|> sort(columns: [“_time”], desc: false)
|> last()
|> map(fn: (r) => {
shiftStart = time(v: strings.replace(v: todayString, t: “T05:00:00.000000000Z”, u: “T${r.startTime}Z”, i: 1))
shiftEnd = time(v: strings.replace(v: todayString, t: “T05:00:00.000000000Z”, u: “T${r.endTime}Z”, i: 1))
return {r with currentShift: time(v: date.sub(d: 0h, from: -5h)) >= shiftStart and time(v: date.sub(d: 0h, from: -5h)) <= shiftEnd}
|> filter(fn: (r) => r[“currentShift”] == true)
|> keep(columns: [“_measurement”, “_value”, “endTime”, “startTime”])
|> yield(name: “last”)
