Hi all,
I’m writing a python code that pings a list of hosts and saves them to a bucket if they respond. It’s simple enough but I keep encountering this error
ValueError: setting an array element with a sequence. The requested array has an inhomogeneous shape after 1 dimensions. The detected shape was (57,) + inhomogeneous part.
However, when I change the range from 5 minutes to 2-3 seconds the code works fine. Also when I test this code on another instance of InfluxDB where we have fewer hosts, it works fine.
I’ll add my entire code below, please take a look.
from influxdb_client import InfluxDBClient, Point, WriteOptions
import numpy as np
import pandas as pd
import warnings
from influxdb_client.client.write_api import SYNCHRONOUS
import requests
import socket
import time
from datetime import datetime, timedelta
urls = "url"
token = ""
organization = ""
# I got warnings about not pivoting the query so I put this in
warnings.simplefilter("ignore", MissingPivotFunction)
# query
last_value = f'''
from(bucket: "bucket")
|> range(start: -5m)
|> filter(fn: (r) => r["_measurement"] == "system")
|> filter(fn: (r) => r["_field"] == "uptime")
|> filter(fn: (r) => r["environment"] == "production")
|> filter(fn: (r) => r["vmtype"] == "vmware")
# connecting to InfluxDB via API, running the query and making a dataframe
client = InfluxDBClient(url="url", token=token, org=organization, debug=False)
system_stats = client.query_api().query_data_frame(org=organization, query=last_value)
df = pd.DataFrame(system_stats)
hosts = df["host"].values.tolist()
#saving the hosts to an external file
with open("hosts.txt", "w") as file:
for host in hosts:
file.write(host + "\n")
write_api = client.write_api(write_options=SYNCHRONOUS)
#reading from that file
with open("hosts.txt", "r") as file:
lines = file.readlines()
#i need to remove everything after the dot because it easier
modified_names = [hostname.split('.', 1)[0] for hostname in lines]
#here i iterate thru all the hosts and lookup their IP's and save them to ip_add
ip_add = []
errors = []
index = 0
while index < len(modified_names):
host = modified_names[index]
try:
ip = socket.gethostbyname(host)
ip_add.append(ip)
except Exception as e:
errors.append(e)
index += 1
#function to get host name, i need this to save the name to influxdb bucket
def getHost(ip):
host = socket.gethostbyaddr(ip)
return host[0]
for host in ip_add:
try:
r = requests.get(f'http://{host}')
data = Point("system").tag("live hosts_test1", getHost(host)).field("host reponse code", r.status_code)
write_api.write(bucket="bucket", org="org", record=data)
pass
