I am trying to collect Bitbucket API data as a json file and push the data to InfluxDB. I am doing this via Jenkins scripted pipeline.
I am not sure how to convert my json data to points as the data will be dynamic. The script executes without any error but I am unable to see my data in InfluxDB
How can I specify which measurement to use.
Code is as below
import groovy.json.*
def result
influxSRV='x.x.x.x:8086'
influxDb='dbname'
measurement = 'ms'
node('master'){
stage('collect'){
sh "curl -XGET -u 'xx:yy' https://x.y.z > output.json"
result = readJSON file: 'output.json'
sh "curl -iX POST \'http://${influxSRV}/write?db=${influxDb}&precision=ms\' --data-binary \'${measurement},${result}\'"
Hello @arrthy,
Welcome! you have two options to get data from a JSON API to InfluxDB. The first is to change the data to line protocol manually so you can write it to the database. The second is to use Telegraf. I recommend checking out the Telegraf file plugin or the exec plugin. I recommend using Telegraf.
telegraf/README.md at release-1.14 · influxdata/telegraf · GitHub
Here is an example you might find useful:
Please note that the example is for 1.x but would work the same for 2.x with a slight change to the Telegraf config. https://docs.influxdata.com/influxdb/v2.0/write-data/no-code/use-telegraf/manual-config/
Unfortunately, I cannot use telegraf. Is it possible to insert multiple values to a field using one post query.
I need only two fields from the JSON generated. I want the DB to look like:
commit user
xx yy
zz cc
aa bb
I tried below
"${result.values.id}".tokenize(',').each
id-> println "${id}"
fieldCommit = "CommitID=${id}"
fieldsList.add(fieldCommit)
userId = "${result.values.author.slug}".tokenize(',').each
fieldUser = "UserID=${id}"
fieldsList.add(fieldUser)
String output = fieldsList.toString().replaceAll("(^\\[|\\]\$)", "");
String fieldsRow = output.toString().replaceAll(" ", "");
sh "curl -iX POST \'http://${influxSRV}/write?db=${influxDb}&precision=ms\' --data-binary \'${measurement},${tagsRow} ${fieldsRow}\'"
But the POST operation fails with below error:
HTTP/1.1 400 Bad Request
Content-Type: application/json
Request-Id: 98bea35d-9e47-11ea-8009-080027379d84
X-Influxdb-Build: OSS
X-Influxdb-Error: unable to parse
