I am having some issues with a json_transformation in outputs.mqtt plugin in Telegraf configuration, with Telegraf version 1.27. I am getting the message: [outputs.mqtt] Could not serialize metric batch for topic "###": argument must be an object or an array of objects
I am doing the following transformation that I previously tried in https://try.jsonata.org/ with version JSONata 1.5.4 and was working, so the transformation is ok: https://try.jsonata.org/5aN2vrMY3
Input data:
"metrics": [
"fields": {
"FeederOverride": 1
"name": "data_1",
"tags": {
"id": "ns=2;s=unit/OPCUA.FeederOverride"
"timestamp": 1696586985
"fields": {
"PressSPM__value": 10
"name": "data_1",
"tags": {
"id": "ns=2;s=unit/OPCUA.PressSPM"
"fields": {
"PressSPM__target": 2
"name": "data_1",
"tags": {
"id": "ns=2;s=unit/OPCUA.PressSPM_target"
Expected output data
"FeederOverride": 1,
"PressSPM": {
"value": 10,
"target": 2
JSON trasnformation
$each($merge([metrics.fields]), function($value, $key) {{
"key": $key,
"value": $value
}}) ~> $reduce(function($acc, $entry) {(
$contains($entry.key, "__")
$outerLevelKey := $split($entry.key, "__")[0];
$innerLevelKey := $split($entry.key, "__")[1];
$merge([$acc, {
$outerLevelKey: $merge([
$lookup($acc, $outerLevelKey),
{ $innerLevelKey: $entry.value }
: $merge([$acc, { $entry.key: $entry.value }])
telegraf.conf
[[outputs.mqtt]]
fieldpass = ["FeederOverride","PressSPM__value", "PressSPM__target"]
topic = "###"
json_transformation = '''
"key": $key,
"value": $value
$merge([$acc, {
{ $innerLevelKey:$entry.value }
batch = true
data_format="json"
But it seems Telegraf is having problems with the line $lookup($acc, $outerLevelKey), because when I remove it, Telegraf is transforming the json (not the way I want, but it’s not complaning). Moreover, if I change the line to $acc.PressSPM, is also working.
So, the only function that is not used in the rest of the transformation is $lookup(), do you know if there is any problem using this function in Telegraf or do you know any other one that I use?
Thanks a lot!
