Rather new with telegraf and I’m having a problem.
I’m reading data from modbus, that’s OK.
My problem is that I need some of that data sent to MQTT in JSON-format. That works, but only partially.
The data I need to send to MQTT is like this :
"Pac" : 175.0,
"E-Total" : 40834.27
What I succeeded to do is this :
"fields" : {
"E-Total" : 58343,
"Pac" : 330
"name" : "modbus",
"tags" : {
"dc" : "server1",
"host" : "server1",
"name" : "SMA-inverter1",
"slave_id" : "3",
"type" : "holding_register"
"timestamp" : 1699707510
The device that is subscribed to the topic can’t handle this.
How do I remove those “superfluous” items ?
I tried using layout = "field", but then, the data is not JSON-formatted, it’s just two new topics.
I was suggested to read this. Is that the way to go ? If yes, where can I find the documentation (plugins ?) ?
Thanks.
