Problem with export data from influxdb OSS 2.0
Hello
I can’t export data to a csv file in any way
I tried different methods, but in the end none of them worked.
influx -database ‘database_name’ -execute ‘SELECT * FROM table_name’ -format csv > test.csv
and other
@Vladlen_Bezymanny in v2 you’ll need to use the influx query command. It will print results in CSV format. See the docs here: influx query | InfluxDB OSS 2.0 Documentation
Thank you
but it gives me an error
influx query ‘from(bucket:“LICZNIK”) |> range(start:-1m)’ --raw --org-id “MyORG”
Error: Unauthorized access.
See ‘influx query -h’ for help
Did you notice the paragraph just under “Examples” at the link dan-moran
provided?
"Authentication credentials
“The examples below assume your InfluxDB host, organization, and token are
provided by the active influx CLI configuration. If you do not have a CLI
configuration set up, use the appropriate flags to provide these required
credentials.”
See also influx - InfluxDB command line interface | InfluxDB OSS 2.0 Documentation
#provide-required-authentication-credentials
Antony.
A little bit late… I ran:
influx query 'from(bucket:"...") |> range(start:-1m)' --raw --org ... --token ... > backup.csv
This just writes all data into a .csv, which u can later write it to InfluxDB.
