Is there any performance read benefit to either of these two variants of ingesting data. Meaning will the way they are ingested impact the performance when extracting more of the data, such as “get the mean rtt for all probes”, or “find all probes who have ttl of 22”.
Hello @eriktar, For Way A
For get mean for all probes
Assuming you have multiple probes, you’ll have to perform an empty group() to group all data from all probes into one table to find the mean.
For find all probes who have ttl of 22
You’ll have to filter for measurement = ping and then filter for ttl>22 and optionally use limit(n:1) to get just one value for each probe or unique()
For Way B
Yould have to join all the probes together since they’re in different measurements/tables to get the data in the same table, before being able to apply a mean across all the data. For this reason I suggest Way A.
This would be a simple filter for measurement = ping_rtt and value > 22
But again because of the mean issue go with WAY A → WINNER
