Possible to delete an item inside a measurement?
Apologies I am not making much sense but I am fairly new to Influx. I have a database called “telegraf” and inside I have a measurement called “apc”. Inside “apc” I have an item called “apctimeremaining”. Is it possible to delete this item? Unfortunately I do not know the appropriate term for “apctimeremaining” inside this measurement.
Here it is inside Grafana:
42%20PM
Again, I apologize in advance if I am not making much sense.
I think by item you mean field. Influx doesn’t support dropping individual fields. Best you can do is to SELECT ... INTO a new measurement without the field, or delete all the series that contain the field.
See [Feature request] Drop field · Issue #6150 · influxdata/influxdb · GitHub
Yes, that’s what I meant. I will just delete the series in this case.
Thank you.
