Running (Telegraf 1.1.0) on a RHEL 7.0 machine, I am getting a permission denied error when restarting telegraf:
â telegraf.service - The plugin-driven server agent for reporting metrics into InfluxDB
Loaded: loaded (/usr/lib/systemd/system/telegraf.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2017-05-15 14:19:12 GST; 7min ago
Docs: https://github.com/influxdata/telegraf
Main PID: 12779 (telegraf)
CGroup: /system.slice/telegraf.service
ââ12779 /usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d
May 15 14:19:12 myhost systemd[1]: Started The plugin-driven server agent for reporting metrics into InfluxDB.
May 15 14:19:12 myhost systemd[1]: Starting The plugin-driven server agent for reporting metrics into InfluxDB...
May 15 14:19:12 myhost telegraf[12779]: 2017/05/15 14:19:12 E! Unable to create /etc/telegraf/telegraf_error.log (open /etc/telegraf/telegraf_error.log: permission denied), using stderr
I only changed logging option in configuration file to quiet = true.
Seems like the file /etc/telegraf/telegraf_error.log cannot be created because of permission issue.
Note that I am running the service as root, and telegraf user is already added to the group telegraf.
Any ideas?
thanks
