I am trying to create a Telegraf config to parse the following JSON data into multiple entries:
"IMEI": "5679789121",
"Model": "X64B1",
"temperature": 18.8,
"humidity": 46.4,
"interrupt": 0,
"interrupt_level": 0,
"battery": 3.57,
"signal": 14,
"1": [
18.5,
43.3,
"2025/03/13 16:36:11"
"2": [
18.4,
43.6,
"2025/03/13 16:21:11"
"3": [
17.8,
43.8,
"2025/03/13 16:06:11"
"4": [
17.6,
43.5,
"2025/03/13 15:51:11"
"5": [
17.5,
43.5,
"2025/03/13 15:36:11"
"6": [
17.8,
43.9,
"2025/03/13 15:21:11"
"7": [
17.7,
44.5,
"2025/03/13 15:06:11"
"8": [
17.7,
44.6,
"2025/03/13 14:51:11"
This is data being captured from a sensor device. It sends the current information (temperature, humidity, battery, signal, etc.), but also the stored information (in this case 1-8). The device uploads once every x time, but captures every 14 minutes.
I would like to store the current information, but also the stored information. The first field in the array is temperature, next humidity, and at last the timestamp when captured.
I think what I am looking for is something like this:
time="2025/03/13 16:36:11",humidity=43.3,temperature=18.5
time="2025/03/13 16:21:11",humidity=43.6,temperature=18.4
time="2025/03/13 16:06:11",humidity=43.8,temperature=17.8
time="2025/03/13 15:51:11",humidity=43.5,temperature=17.6
and so on.
Ideally the time should become the data timestamp.
I’ve looked into both json_v2 and xpath input. But got stuck on both, without any usefull result.
