For a very simple input as shown (apologies for the message string internal formatting but it is what it is and should be seen as a string from the parsing perspective.)
"uptimeSeconds": 441402.94,
"status": 2,
"messages": [
"[Alarm 0] Error - Weather data not available",
"[Alarm 1] Error - 3 configured nodes have not reported SoftwareInfo: [adam,meanwell,eltek]",
"[Alarm 2] Warning - 6 configured nodes have old or missing heartbeats: exeltech,linovision,adam,vertiv,meanwell,eltek]",
"[Alarm 3] Error - Battery info not available",
"[Alarm 4] Error - Generator info not available",
"[Alarm 5] Warning - Generator taking too long to stop"
The object configuration should parse the array according to the documentation but fails to do so.
[[inputs.kinesis_consumer.json_v2]]
[[inputs.kinesis_consumer.json_v2.object]]
path = "messages"
disable_prepend_keys = true
tags = ["messages"]
optional = true
The error log shows this output -
2025-02-13T15:04:16Z D! [serializers.influx] could not serialize field "": invalid field key; discarding field
I am referencing this documentation - JSON v2 input data format | Telegraf Documentation
