Given the following from the vendor mib
-- 1.3.6.1.4.1.9070.1.2.5.7.8.4.3
gnssSatlist OBJECT-TYPE
SYNTAX DisplayString (SIZE(1..128))
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"Displays the GNSS satellite tracking information in the
format of:
N,X1,Y1,C1,...,XN,YN,CN
defined as follows:
N Number of satellites. If one or more satellites
are available, Xi,Yi,Zi follows N.
Xi Satellite vehicle number.
Yi Index
Ci GNSS Constellations.
Example 1 :
11,X2,Y1,CBeiDou,X3,Y2,CBeiDou,X5,Y3,CBeiDou,X9,Y4,CBeiDou,X3,Y5,CGLONASS,X4,Y6,CGLONASS,X13,Y7,CGLONASS,X14,Y8,CGLONASS,X15,Y9,CGLONASS,X18,Y10,CGLONASS,X19,Y11,CGLONASS.
Interpretation of above example
11 (Number of Satellites)
X2, Y1, CBeiDou : X2 (satellite vehicle number), Y1 (Index), CBeiDou (constellation)
Example 2:
17,X1,Y1,CGPS,X10,Y2,CGPS,X11,Y3,CGPS,X14,Y4,CGPS,X16,Y5,CGPS,X20,Y6,CGPS,X22,Y7,CGPS,X25,Y8,CGPS,X26,Y9,CGPS,X27,Y10,CGPS,X31,Y11,CGPS,X32,Y12,CGPS,X40,Y13,CSBAS,X3,Y14,CBeiDou,X5,Y15,CBeiDou,X7,Y16,CBeiDou,X9,Y17,CBeiDou
Example 3:
0
No Satellites
::= {gnss 3}
which is queried via the following
[[inputs.snmp.field]]
name = "sat_list"
oid = "S650::gnssSatlist.0
I would like to parse this out so that I have say field satellite with the tags vehicle and constellation. I don’t see much value for the count as this could then be derived by doing a sum on the data for the interval or index (seems to just be an index into the list).
Parsing the total count is easily done with a regex but what I don’t know how to do is chunk up the returned string to multiple entries. If it is possible to pass this field to a shell script I could whip something up in bash/python easy enough but I am not sure how to make a call for just the field (maybe just the metric) to be processed by the script.
so from the example (#2) ^^ in the mib it would come out to something like this
satellite vehicle=1,constellation=GPS
satellite vehicle=10,constellation=GPS
satellite vehicle=9,constellation=BeiDou
Thoughts/pointers appreciated
