I have a go-eCharger that can be managed also with MQTT.
Two of the topics it send are arrays such as:
go-eCharger/201397/nrg = [233.74,2.48,3.41,1.24,0,0,0,0,0,0,0,0,0,0,0,0]
go-eCharger/201397/tma = [35.5,30.5]
No I am able to parse the fields in new keys t1 and t2 with:
topic = "go-eCharger/+/+"
measurement = "measurement/_/_"
tags = "_/chargerid/field"
[[processors.regex]]
[[processors.regex.fields]]
key = "value"
pattern = '^\[(\d+\.?\d*),(\d+\.?\d*)\]$'
replacement = "${1}"
result_key = "t1"
key = "value"
replacement = "${2}"
result_key = "t2"
[[processors.converter]]
[processors.converter.fields]
float = ["t1", "t2"]
However that result the new values to be strings, when running telegraf --test for the configuration.
> go-eCharger,chargerid=201397,host=pi.oh2th.fi t1="35.5",t2="30",tma="[35.5,30]" 1663598657338594386
How can I make sure that the result_keys would be float? Even with the converter but that does not change anything for the result.
