Hi there,
We’re all know access to a record, such as:
filter(fn: (r) => r["_field"] == "abc")
Can we do something like this?
p = "_field"
filter(fn: (r) => r[p] == "abc")
Hi there,
p = "_field"
Hello @Nam_Giang,
Unfortunately not yet, but will be soon!
As of Flux 0.134.0, there is a way to do this, so depending on which version of InfluxDB you’re using, it may be available to you. It’s the experimental record.get() function. It would look something like this:
import "experimental/record"
p = "_field"
|> filter(fn: (r) => record.get(r: r, key: p, default: "example-default-value") == "abc")
