Does anyone have a proper how to guide to get data from Openwrt to Influxdb v2?
Most articles out there are in regards to older versions of Influxdb.
It used to be collectd → influxdb → Grafana.
Now I believe it is collectd → telegraf ->influxdb → Grafana.
On the Openwrt Router I followed these steps.
https://blog.christophersmart.com/2019/09/09/monitoring-openwrt-with-collectd-influxdb-and-grafana/
Telegraf won’t load it keeps failing…
adding parser failed: open /usr/share/collectd/types.db: no such file or directory
This is my Telegraf config file right now.
agent]
interval = “10s”
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = “0s”
flush_interval = “10s”
flush_jitter = “0s”
precision = “”
hostname = “”
omit_hostname = false
[[inputs.socket_listener]]
service_address = “udp://:25826”
data_format = “collectd”
collectd_auth_file = “/etc/collectd/collectd.auth”
collectd_security_level = “encrypt”
collectd_typesdb = [“/usr/share/collectd/types.db”]
collectd_parse_multivalue = “split”
[inputs.socket_listener.tags]
bucket = “collectd”
[[outputs.influxdb_v2]]
urls = [“http://IP:8086”]
token = “Token Key”
organization = “Org ID”
bucket = “collectd”
[outputs.influxdb_v2.tagpass]
bucket = [“collectd”]
Where is the types.db file suppose to be copied to the Influxdb or telegraf docker?
