Hi there,
just getting acquainted with influxdb and telegraf to replace a collectd, rrd and CGP stack.
i use an influxdb v2 docker container (on a debian system) and installed several telegraf on the different machines.
on openbsd i installed telegraf via “ports”, therefore it is telegraf-1.13.4p2
I’m having an issue where the CPU reported is wrong
The graph from the UI shows a lot of CPU use (see screen cap):
while on cli with vmstat it show almost 0 usage :
procs memory page disk traps cpu
r s avm fre flt re pi po fr sr sd0 int sys cs us sy id
1 80 57M 2694M 3 0 0 0 0 0 0 116 16 113 0 0 100
1 80 57M 2693M 808 0 0 0 0 0 0 148 759 205 0 2 98
0 80 57M 2693M 3 0 0 0 0 0 0 227 21 220 0 0 100
0 80 57M 2693M 3 0 0 0 0 0 0 70 21 78 0 0 100
0 80 57M 2693M 656 0 0 0 0 0 0 162 330 176 0 2 98
0 80 57M 2693M 4 0 0 0 0 0 0 80 21 92 0 0 100
0 80 57M 2693M 3 0 0 0 0 0 0 127 9 120 0 0 100
0 80 57M 2693M 624 0 0 0 0 0 0 100 327 131 0 2 98
0 80 57M 2693M 3 0 0 0 0 0 0 110 9 104 0 0 100
0 80 57M 2693M 4 0 0 0 0 0 0 114 21 112 0 0 100
0 80 57M 2693M 3 0 0 0 0 0 0 91 14 94 0 0 100
0 80 57M 2693M 611 0 0 0 0 0 0 103 328 134 0 2 98
any idea what could be the issue ?
telegraf 1.13 not okay with influxdb v2 ?
thanks in advance for your help !
