Old conf not reading the new
Hello
I have a telégraf running in a Windows server 2022
I had a 1.23 versión
And in my conf had a kafka output with a broker dns
Server1292 but It was an error connect to dns and i need to use ip broker instead
I delete all the files and install new telegraf 1.30 with new conf broker 191.271.18.1 (ip instead dns)
Still i have and error with dns. Is like still reading the old configuration, cache problem?
Some hace the same error?
Do a DNS look up on your system and see if DNS is still showing the old hostname. This sounds like a DNS issue if it is the case.
thanks for anwer
if i do this in a server with no problem and similar telegraf conf:
C:>nslookup server1292
Server: Bancadc01.lu
Address: 172.30.251.192
server with the problem:
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 172.30.255.17
telegraf error:
! [agent] Error writing to outputs.kafka: kafka: Failed to produce message to topic m-wintel: dial tcp: lookup server1292 getaddrinfow: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
line for telegraf conf: output kafka
brokers = [“172.30.42.193:9093”]
Thanks, that looks like the DNS is not configured on that system correctly or the server itself is down or not working. There isn’t really anything Telegraf can do about a bad or down DNS server.
thank you! then is not a telegraf issue
I didnt understand that If i using a ip like brokers = [“172.30.42.193:9093”] telegraf turn me an error with server dns name lookup server1292 for this reason i thought it was a telegraf issue
