Error from broker when executing [root@scottsys ~]# telegraf --config /etc/telegraf/telegraf.conf
Telegraf 1.17.1
Kafka 2.13-2.7.0
telegraf.conf
[root@scottsys ~]# cat /etc/telegraf/telegraf.conf
[tags]
Configuration for telegraf agent
[agent]
interval = “60s”
debug = true
quiet = false
round_interval = true
metric_batch_size = 8000
metric_buffer_limit = 20000
flush_interval = “60s”
flush_jitter = “30s”
precision = “s”
[[outputs.kafka]]
URLs of kafka brokers
brokers = [“127.0.0.1:9092”]
Kafka topic for producer messages
topic = “hardwaremetrics”
enable_tls = false
tls_ca = “/etc/telegraf/ca.cer.pem”
tls_cert = “/etc/telegraf/client.cer.pem”
tls_key = “/etc/telegraf/client.key.pem”
insecure_skip_verify = true
DR - ZT
Error
2021-02-17T23:17:10Z I! Starting Telegraf 1.17.2
2021-02-17T23:17:10Z I! Loaded inputs: redfish (2x)
2021-02-17T23:17:10Z I! Loaded aggregators:
2021-02-17T23:17:10Z I! Loaded processors: converter
2021-02-17T23:17:10Z I! Loaded outputs: kafka
2021-02-17T23:17:10Z I! Tags enabled: dc=welktxef.vzcpe.net host=scottsys
2021-02-17T23:17:10Z I! [agent] Config: Interval:1m0s, Quiet:false, Hostname:“scottsys”, Flush Interval:1m0s
2021-02-17T23:17:10Z D! [agent] Initializing plugins
2021-02-17T23:17:10Z W! [kafka] enable_tls is deprecated, and the setting does nothing, you can safely remove it from the config
2021-02-17T23:17:10Z D! [sarama] Initializing new client
2021-02-17T23:17:10Z D! [sarama] client/metadata fetching metadata for all topics from broker 127.0.0.1:9092
2021-02-17T23:17:10Z D! [sarama] Connected to broker at 127.0.0.1:9092 (unregistered)
2021-02-17T23:17:10Z D! [sarama] client/metadata got error from broker -1 while fetching metadata: read tcp 127.0.0.1:45836->127.0.0.1:9092: read: connection reset by peer
2021-02-17T23:17:10Z D! [sarama] Closed connection to broker 127.0.0.1:9092
2021-02-17T23:17:10Z D! [sarama] client/metadata no available broker to send metadata request to
2021-02-17T23:17:10Z D! [sarama] client/brokers resurrecting 1 dead seed brokers
2021-02-17T23:17:10Z D! [sarama] client/metadata retrying after 250ms… (3 attempts remaining)
2021-02-17T23:17:11Z D! [sarama] client/metadata fetching metadata for all topics from broker 127.0.0.1:9092
2021-02-17T23:17:11Z D! [sarama] Connected to broker at 127.0.0.1:9092 (unregistered)
2021-02-17T23:17:11Z D! [sarama] client/metadata got error from broker -1 while fetching metadata: read tcp 127.0.0.1:45838->127.0.0.1:9092: read: connection reset by peer
