OAuth Authentication / Authorization
I know Chronograf supports OAuth for authenticating users: cf this link.
Is this support planned for InfluxDB2 GUI?
If so, is there a date estimation for when it will get integrated?
I find it overall difficult to get information on InfluxDBv2 roadmap.
Best regards
Hi Pmazon ,
I don’t know , I just reply so that your post does not go unnoticed … :slight_smile:
I’ll speak to our product team, but I suspect this won’t be in the first GA release of InfluxDB 2 (though I could be wrong).
I’ll let you know what I find out.
Thanks, MarcV; your comment reminded me about this one.
Thank you MarcV & rawkode.
I look forward to what you’ll find out.
Hi @pmazon,
As I suspected, this won’t be in our first GA release.
Could you open an issue (GitHub - influxdata/influxdb: Scalable datastore for metrics, events, and real-time analytics) with your suggestion? This will allow our product team to keep you informed :+1:
Alrighty, I submitted an issue in github.
Reference is here.
Hello, is the support for oauth2 in the roadmap for InfluxDB 2 OSS? that would help us to migrate from Chronograf to the InfluxDB 2 UI and use some of the new UI capabilities available there. Any update is very much appreciated, thank you!
