Hi there,
I have a monitoring task that outputs OK/CRIT level and I need to send out notification only when there’s a change in the level.
Here’s the current execution timing and monitoring data:
monitoring task: 5min |...OK CRIT OK OK OK OK...
notification rule: 10min, 2m offset |... ^ ^ ^ ...
My question is that, I only receive the notification for the OK → CRIT and lost the CRIT → OK message. Essentially on Slack, I see multiple “xxxx level is now CRIT”, and never see it comes back OK.
Here’s my monitoring task:
import "influxdata/influxdb/monitor"
import "experimental"
import "slack"
option task = {name: "network down", every: 5m}
slack_channel =
slack["endpoint"](url: "https://hooks.slack.com/services/x/y")
from(bucket: "my-bucket")
|> range(start: -1d)
|> filter(fn: (r) => r["_measurement"] == "networking" and r["_field"] == "ping_rtt")
|> schema.fieldsAsCols()
|> monitor.deadman(t: experimental.subDuration(d: 5m, from: now()))
|> monitor.check(
crit: (r) => r.dead == true,
ok: (r) => r.dead == false,
messageFn: (r) => "anything",
data: {
_check_name: "Network Status",
_check_id: "network_status",
_type: "deadman",
tags: {deadman: "deadman"},
And here’s my notification task:
import "slack"
option task = {name: "network down slack alert", every: 10m, offset: 2m}
slack_channel =
monitor["from"](start: -15m, fn: (r) => r["_check_name"] == "Network Status")
|> monitor.stateChangesOnly()
|> map(fn: (r) => ({r with _value: if r["_level"] == "crit" then "down" else "ok"}))
|> group(columns: ["host"])
|> first()
|> slack_channel(
mapFn: (r) =>
channel: "",
text: "host:${r.host} network status: ${r._value}",
color: if r["_level"] == "crit" then "danger" else "good",
I might misuse the first() function, but how do I notify only the latest level ? What I want to achieve is on Slack I want to see some things go down and later on see them coming up. If I leave out the first(), it’d just spitting up/down up/down multiple times in the channel that doesn’t make sense.
