Not able to see the measurements immediately in buckets
I have created measurements and entered the data thru line protocol into buckets, it shown successfully data has been entered and saved. From the data explorer, when I try to see the data I am not able to see the data.
Regards
Sudheer
Hello @AVVS_Sudheer,
Are you able to see it now?
Did you change the time range in the UI to include the timestamp of the points you wrote?
Have you tried querying with the API or CLI to verify that your data is written succesfully?
Can you switch to the script editor and see your data if you write a Flux query?
Still not able to see the data
Regards
Sudheer
