I am still trying to figure out why Grafana shows “no data” and InfluxDB reports lots of data in “cached”, however, I suddenly lost any kind of connection to the database and I don’t know why. I already deleted everything and started from scratch since I am still in the exploration phase but I can’t understand why I get no user provided when I clearly provide a user.
$ curl -G http://localhost:8086/query -u admin:SUPER_SECRET_PASSWORD --data-urlencode "q=SHOW DATABASES"
{"error":"error authorizing query: no user provided"}
I created the admin user via the Ansible plugin, which worked perfectly fine for the initial setup.
What is happening?
Hello @tamasgal,
What version of InfluxDB are you using?
Are you sure that you have set everything up properly? The order of things should be:
- InfluxDB is running with no http-auth setup.
- Create an admin user
CREATE USER admin WITH PASSWORD 'pass' WITH ALL PRIVILEGES .
- Shut down InfluxDB.
- Edit the configuration file and set
auth-enabled = true in the [http] section.
- Restart InfluxDB ensuring you’re using the configuration file you edited.
Then your cURL command should work:
I like including as params.
$ curl -G "http://localhost:8086/query?u=admin&p=pass" --data-urlencode "q=SHOW DATABASES"
{"results":[{"statement_id":0,"series":[{"name":"databases","columns":["name"],"values":[["_internal"]]}]}]}
Thanks, somehow the admin role with privileges ALL as not set up properly. The error message is really confusing
anyways, got it working now. Still fighting though to get the collected data displayed.
Btw. I think my other post is hidden due to the spam regulations or No data available but tons of values cached?
