Good morning,
trying to upgrade my telegraf container from 1.18.3 to 1.19.1 telegraf seems not liking my config anymore.
[[inputs.mqtt_consumer]]
servers = ["tcp://192.168.178.35:1883"]
## MQTT QoS, must be 0, 1, or 2
qos = 0
## Topics to subscribe to
topics = [
# if true, messages that can't be delivered while the subscriber is offline
# will be delivered when it comes back (such as on service restart).
# NOTE: if true, client_id MUST be set
persistent_session = false
# If empty, a random client ID will be generated.
client_id = "grafana"
## username and password to connect MQTT server.
# username = "telegraf"
# password = "metricsmetricsmetricsmetrics"
## Optional SSL Config
# ssl_ca = "/etc/telegraf/ca.pem"
# ssl_cert = "/etc/telegraf/cert.pem"
# ssl_key = "/etc/telegraf/key.pem"
## Use SSL but skip chain & host verification
## Data format to consume.
## Each data format has it's own unique set of configuration options, read
## more about them here:
data_format = "value"
data_type="float"
causes the following exception on startup:
2021-07-19T04:43:34Z E! [telegraf] Error running agent: starting input inputs.mqtt_consumer: network Error : dial tcp 192.168.178.35:1883: connect: no route
to host
Maybe anyone can help?
Thanks and regards
Max
