servers = [“tcp://127.0.0.1:1883”] doesn’t work
servers = [“tcp://192.168.100.221:1883”] works
Mosquitto and Telegraf are running in Docker
I don’t think that it is a Telegraf issue but maybe related to my settings. But I cannot figure out what !
`> pi@pi-home-test:~/docker $ sudo lsof -i TCP
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
container 501 root 13u IPv4 11645 0t0 TCP localhost:35953 (LISTEN)
sshd 513 root 3u IPv4 11635 0t0 TCP *:ssh (LISTEN)
sshd 513 root 4u IPv6 11637 0t0 TCP *:ssh (LISTEN)
sshd 1611 root 4u IPv4 15809 0t0 TCP pi-home-test:ssh->michel-HP-EliteBook-840-G3:41478 (ESTABLISHED)
sshd 1767 pi 4u IPv4 15809 0t0 TCP pi-home-test:ssh->michel-HP-EliteBook-840-G3:41478 (ESTABLISHED)
docker-pr 7815 root 3u IPv4 42485 0t0 TCP pi-home-test:1883->172.18.0.3:43300 (ESTABLISHED)
docker-pr 7815 root 4u IPv4 35102 0t0 TCP *:1883 (LISTEN)
docker-pr 7815 root 5u IPv4 42487 0t0 TCP 172.17.0.1:42536->172.17.0.2:1883 (ESTABLISHED)
docker-pr 10146 root 4u IPv4 37778 0t0 TCP *:8086 (LISTEN)
docker-pr 10997 root 4u IPv4 43393 0t0 TCP *:3000 (LISTEN)`
and
`pi@pi-home-test:~/docker $ ping localhost -c1
PING localhost(localhost (::1)) 56 data bytes
64 bytes from localhost (::1): icmp_seq=1 ttl=64 time=0.149 ms— localhost ping statistics —
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.149/0.149/0.149/0.000 ms
