I am a novice in more than one respect and I am trying to copy my ‘openhab+influxdb+grafana’ environment from a RPi4 into a headless NUC .
Found some links on the internet that helps me with this process.
Openhab and restoring its backup went flawlessly (as far I can see).
With Influxdb 1.8.10 I am struggeling with my users. I expect that for example that ‘INFLUXDB_ADMIN_USER’ will create an influx admin user which is visible with:
nuc@nuc:/opt/openhab$ docker exec -it influxdb18 /bin/sh
# influx
Connected to http://localhost:8086 version 1.8.10
InfluxDB shell version: 1.8.10
> show users
user admin
But it wasn’t.
BTW no problem to create it manually with:
CREATE USER admin WITH PASSWORD ‘adminpass’ WITH ALL PRIVILEGES
So my question is why did my docker-influx command not create an admin user?
Are my expectations incorrect?
(below simplified docker-influx version did not do the expected thing also).
docker run -p 8091:8091 \
-e INFLUXDB_ADMIN_USER=admin \
-e INFLUXDB_ADMIN_PASSWORD=adminpass \
-v influxdb:/var/lib/influxdb \
influxdb:1.8
Have tried to add and play with:
INFLUXDB_HTTP_AUTH_ENABLED=false
INFLUXDB_ADMIN_ENABLED=true
But that did not make a difference
Your comments to put me on the right track would be appreciated.
Some details:
NUC7i3BNK 12Gb Ubuntu server Ubuntu 22.04.1 LTS
Docker version:
nuc@nuc:/opt/openhab$ docker version
Client: Docker Engine - Community
Version: 20.10.21
API version: 1.41
Go version: go1.18.7
Git commit: baeda1f
Built: Tue Oct 25 18:01:58 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.21
API version: 1.41 (minimum version 1.12)
Git commit: 3056208
Built: Tue Oct 25 17:59:49 2022
Experimental: false
containerd:
Version: 1.6.9
GitCommit: 1c90a442489720eec95342e1789ee8a5e1b9536f
runc:
Version: 1.1.4
GitCommit: v1.1.4-0-g5fd4c4d
docker-init:
Version: 0.19.0
GitCommit: de40ad0
