I deployed on docker InfluxDB v 1.8.10 with command:
docker run --name influxdb -t
-e INFLUXDB_HTTP_AUTH_ENABLED=“true”
-e INFLUXDB_DB=“mydatabase”
-e INFLUXDB_USER=“user”
-e INFLUXDB_USER_PASSWORD=“user”
-e INFLUXDB_ADMIN_USER=“admin”
-e INFLUXDB_ADMIN_PASSWORD=“admin”
–restart unless-stopped
-d influxdb:1.8.10
When I connect I see that the new Admin user is created.
Now I would like to deploy it on Kubernetes, this is my code:
apiVersion: apps/v1
kind: StatefulSet
metadata:
namespace: mon-grafana
spec:
serviceName: influxdb
replicas: 3
selector:
matchLabels:
app: influxdb
template:
metadata:
labels:
app: influxdb
spec:
containers:
- name: influxdb
image: influxdb:1.8.10 #bitnami/influxdb:1.8.10 #influxdb:1.8.10
ports:
- containerPort: 8086
protocol: TCP
resources:
requests:
cpu: 250m
memory: 500Mi
limits:
cpu: 2
memory: 500Mi
env:
- name: INFLUXDB_HTTP_AUTH_ENABLED
value: “true”
- name: INFLUXDB_DB
value: “mydatabase”
- name: INFLUXDB_USER
value: “user”
- name: INFLUXDB_USER_PASSWORD
value: “user”
- name: INFLUXDB_ADMIN_USER
value: “admin”
- name: INFLUXDB_ADMIN_PASSWORD
value: “admin”
volumeMounts:
- name: pvc-influxdb
mountPath: /var/lib/influxdb
- name: influxdb-config
mountPath: “/etc/influxdb/influxdb.conf”
subPath: influxdb.conf
securityContext:
allowPrivilegeEscalation: false
volumes:
configMap:
items:
- key: influxdb.conf
path: influxdb.conf
volumeClaimTemplates:
-metadata:
spec:
accessModes: [ “ReadWriteOnce” ]
resources:
requests:
storage: 2Gi
and this is my infliuxdb.conf file:
root@influxdb-0:/# cat /etc/influxdb/influxdb.conf
reporting-enabled = false[meta]
dir = “/var/lib/influxdb/meta”[data]
dir = “/var/lib/influxdb/data”
wal-dir = “/var/lib/influxdb/wal”
max-series-per-database = 1000000
max-values-per-tag = 100000
index-version = “tsi1”
max-index-log-file-size = “100k”[http]
log-enabled = false
enabled = true
bind-address = “0.0.0.0:8086”
https-enabled = false
flux-enabled = true
but when I try to connect I receive this error:
root@influxdb-0:/# influx -username admin -password admin
Connected to http://localhost:8086 version 1.8.10
InfluxDB shell version: 1.8.10show databases;
ERR: error authorizing query: create admin user first or disable authentication
Warning: It is possible this error is due to not setting a database.
Please set a database with the command “use ”.
What did I miss?
