I am attempting to use the net_response input plugin to monitor a Squid proxy server but I do not seem to be getting the expected results. I have even reviewed the golang code and duplicated the section that seems to not work in Go Play and I get the expected results for the regexp portion but not from the plugin. Just wondering if the plugin code has been included in the latest build.
What I am trying to do is connect to one of my Squid proxies at 10.10.2.5:8080 and send a “HEAD http://www.google.com” string and get back a “HTTP/1.0 200 OK” string. See below …
[[inputs.net_response]]
protocol = "tcp"
address = "10.10.2.5:8080"
timeout = "1s"
send = "HEAD http://www.google.com"
expect = "HTTP/1.0 200 OK"
tagexclude = ["host","role","rack","rack-name","dc","network"]
If I run a test I get a string_found=false and no result_type at all. See below …
# telegraf --config squid.conf --test
* Plugin: inputs.net_response, Collection 1
> net_response,server=10.10.2.5,port=8080,protocol=tcp string_found=false,response_time=1.000848022 1502923238000000000
The actual string returned when I do this through telnet is this …
# telnet 10.10.2.5 8080
Trying 10.10.2.5...
Connected to 10.10.2.5.
Escape character is '^]'.
HTTP/1.0 200 OK
Date: Wed, 16 Aug 2017 20:06:21 GMT
Expires: -1
Cache-Control: private, max-age=0
Content-Type: text/html; charset=ISO-8859-1
P3P: CP="This is not a P3P policy! See https://www.google.com/support/accounts/answer/151657?hl=en for more info."
Server: gws
X-XSS-Protection: 1; mode=block
X-Frame-Options: SAMEORIGIN
Set-Cookie: NID=110=WwV22ciCaAo2Lr8gdnh250iFQN-D9A_R-DzbJ5BpL-_TtX3_Pxc-lX5G8Vz4SmwMMLZWatSLXEA0JwLjGB-BxHzxc2qgul2HTUFzfr2Al8QL8Yq8LVUykQY9LqOdCjgf; expires=Thu, 15-Feb-2018 20:06:21 GMT; path=/; domain=.google.com; HttpOnly
Accept-Ranges: none
Vary: Accept-Encoding
X-Cache: MISS from ninja
X-Cache-Lookup: MISS from ninja:8080
Via: 1.0 ninja (squid)
Connection: close
Connection closed by foreign host.
Looking closely at the code I should get a match in regexp if my expect string is contained within the response. The fact that the code tests Ok in Go Play (regexp section only) and that I never see “result_type” in the output leads me to believe that the code I see at GitHub is not really the code that is running.
Running Telegraf v1.3.5 (git: release-1.3 7192e68b2423997177692834f53cdf171aee1a88).
Because of this I have had to write my own code and use the Exec input to do things like this. Have others had better success with this plugin?
Not a GoLang guy but including my Go Play code for posterity …
package main
import (
"fmt"
"regexp"
func main() {
var data = `HTTP/1.0 200 OK
Expires: -1
Server: gws
Accept-Ranges: none
Via: 1.0 ninja (squid)`
var Expect = "HTTP/1.0 200 OK"
re := regexp.MustCompile(`.*` + Expect + `.*`)
find := re.FindString(string(data))
if find != "" {
fmt.Println("result_type = success")
fmt.Println("string_found = true")
} else {
fmt.Println("result_type = string_mismatch")
fmt.Println("string_found = false")
If I run this I get …
string_found = true
Code I am viewing is at telegraf/net_response.go at master · influxdata/telegraf · GitHub
