Mutual TLS support in InfluxDB3 Java Client
Hi InfluxDB Community,
I’m currently integrating the InfluxDB3 Java client (v1.2.0) into Kafka Connect environments and have encountered some SSL/TLS limitations compared to the Influxdb v2 Java client and other standard HTTP clients
Current InfluxDB3 SSL Support:
  • Server certificate validation (enable/disable)
  • Custom CA certificates (PEM format only)
  • Basic TLS protocol selection (v1.2/v1.3)
Missing Enterprise Features:
  • Mutual TLS (mTLS) - No client certificate authentication support
  • Multiple certificate formats - Only PEM supported, no JKS/PKCS12
  • Keystore support - Cannot load client certificates from keystores
  • Advanced SSL configuration - No hostname verification control, trust strategies, etc.
These limitations prevent deployment in enterprise environments requiring client certificate authentication or existing PKI infrastructure using JKS/PKCS12 formats.
Questions:
  1. Are there plans to enhance SSL/TLS capabilities in future releases?
  2. Is there a roadmap for mTLS support?
Thanks for raising these @AnshJ, discussing these internally.
Hi @AnshJ, thanks for reaching out.
Can you please clarify how you configure extended SSL options in the v2 client? Am I correct in assuming that you’re using a custom OkHttpBuilder?
Thanks for your response—it will help us better understand your requirements.
Best
Hi @bednar @suyash,
Yes, you’re absolutely correct.
The v2 client enables extended SSL options through custom OkHttpClient configuration:
OkHttpClient.Builder httpBuilder = new OkHttpClient.Builder()
.sslSocketFactory(sslContext.getSocketFactory(),
                  (X509TrustManager) tmf.getTrustManagers()\[0\])
.hostnameVerifier(customHostnameVerifier);
Would it be feasible to add similar support for SSL/TLS in V3 either through HTTP client injection to v3, or extending ClientConfig with enterprise SSL options like:
  • keyStorePath / keyStorePassword
  • keyStoreType (JKS/PKCS12)
  • customTrust Store support
This would enable enterprise adoption without requiring infrastructure changes to accommodate PEM-only workflows.
Following up @bednar , @suyash
Did you guys checked this? It is required to have SSL enabled for Self hosted databases.
Hi @AnshJ can you please open this as issue here, be easier to track and see updates: GitHub · Where software is built Thanks!
