Muti databases in Influxdb
InfluxDB shell version: 1.6.2
show databases
name
BASE1
BASE2
I would like under Grafana, to combine in a graph the measurements of the 2 bases
BASE1 = measurement_A / counter1
BASE2 = measurement_B / counter2
In Grafana is it possible to combine the 2 counters: counter1 + counter2
But in Grafana, you can only choose one Data Source
Create a BASE3 and copy the 2 measurements ?
thanks in advance
This isn’t possible with InfluxQL however if you enable Flux you can do this by querying multiple buckets
