I’m receiving collectd data via collectd-mod-mqtt plugin (openwrt).
it sends on the data in format timestamp:value\x00
that is a zero at the end.
I was able to parse it using CSV data format, as string, and then I can use processors.regex to remove the last \x00
The problem is that I can’t format it from string to integer with processors.converter
[[processors.converter]]
[[processors.converter.fields]]
integer = ["value"]
It has no effect.
