Is there any plugin like this one https://docs.fluentd.org/v0.12/articles/in_http for telegraf?
Kind regards
Cayetano
Kind regards
Cayetano
As I understand, this plugin check an external URL and get the metrics, the fluentd plugin create an endpoint listening wait for data like webhook
Ahh, yes you are correct. We don’t have this right now, but keep an eye on this feature request for updates: Add input that accepts all input data formats using HTTP · Issue #3226 · influxdata/telegraf · GitHub
Are you planning to use it with JSON data?
yes I’m going to use json
