I want to use the Disk Input Plugin to monitor the disk usage (size) of my opt folder and all the folders under (i use the folder and subfolders for persistent storage for my docker containers)
Here is my docker compose for telegraf: (note that I am also using it to monitor my containers)
telegraf:
container_name: telegraf
image: telegraf:latest
volumes:
- /opt/telegraf/telegraf.conf:/etc/telegraf/telegraf.conf
- /var/run/docker.sock:/var/run/docker.sock
- /:/hostfs:ro
- /proc/1/mounts:/foo/etc/mtab
environment:
- DOCKER_INFLUXDB_INIT_ORG=myrgangen
- DOCKER_INFLUXDB_INIT_BUCKET=DockerMonitoring
- DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=(removed)
- HOST_MOUNT_PREFIX=/hostfs
- HOST_PROC=/hostfs/proc
- HOST_ETC=/foo/etc
links:
- influxdb
depends_on:
- influxdb
ports:
- 8125:8125
- 8092:8092
- 8094:8094
and here is my [[inputs.disk]] configuration in telegraf.conf:
[[inputs.disk]]
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "iso9660", "overlay", "aufs", "squashfs"]
but when run the container, I don’t see my /opt folder in the path Tag?
