i’ve got some strange problem. After moving my database instance to docker (from and to 1.8), and restoring the data into the database, there is some mixup.
Here is a screenshot while im looking in the database with InfluxDB Studio:
Hello @Andre1Becker,
Possibly? Honestly, Im not sure. I’ve never encountered this with Select Into with InfluxQL.
In fact I’m pretty sure you have to write data into a new measurement:
How are you querying for your data?
What is InfluxDB Studio?
My guess is that tool is causing the error. Id suggest reaching out to them.
first of all, thanks for taking your time to help me with this. Much appreciated!
Influx Studio is a GUI for Windows to look into databases - this is an older App. But im more a GUI Guy
The Error message i get in openHAB is:
Could not find item 'COST.GAS.DAILY' in registry
Which essential means that openHAB could not find the Measurement item COST.GAS.DAILY in influx.
Normally that error occurs when there is no Item in openHAB with that name. But that’s not true in my case. The item exists and the measurement with that exact name exists also.
I will add more infos later as im running out of time right now
