Hi Community!
I am using the gnmi input plugin for some Juniper devices, and am noticing missing field for a particular measurement (bgp_neighbors_enabled).
Consider the following output, which consists of all expected tags and fields
bgp_neighbors_enabled{auth_password="(null)", description="(null)", instance="telegraf:9126", instance_name="xxx", job="telegraf", messages_received_last_notification_error_code="CEASE", messages_sent_last_notification_error_subcode="UNSPECIFIC", neighbor_address="x.x.x.x", path="/network-instances/network-instance/protocols/protocol/bgp/neighbors/neighbor", peer_group="group1", peer_type="EXTERNAL", session_admin_status="START", session_state="ESTABLISHED", session_status="RUNNING", source="xx-br1"}
In contract, the same measurement for another BGP peer is missing the fields session_state
and peer_type
bgp_neighbors_enabled{instance="telegraf:9126", instance_name="xxx", job="telegraf", messages_received_last_notification_error_code="NONE", messages_received_last_notification_error_subcode="UNSPECIFIC", neighbor_address="x.x.x.x", path="/network-instances/network-instance/protocols/protocol/bgp/neighbors/neighbor", peer_group="group2", session_admin_status="START", session_status="RUNNING", source="xx-br1"}
A few other observations:
- I can confirm the polled device is returning the complete fields, as verified by running gnmic on the telegraf server. The issue appears to be on Telegraf-end.
- I have tried bumping up/reducing the various intervals within the Telegraf config.
- The issue appears to be intermittent. There will be different BGP peers with no
session_state
&peer_type
at different times.
My telegraf config is as follows:
[agent]
interval = "10s"
round_interval = true
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = "0s"
omit_hostname = true
snmp_translator = "gosmi"
debug = true
[[outputs.prometheus_client]]
listen = ":9126"
metric_version = 2
path = "/metrics"
string_as_label = true
export_timestamp = true
[[inputs.gnmi]]
addresses = [
"xxxx",
encoding = "proto"
[[inputs.gnmi.subscription]]
name = "bgp_neighbors"
origin = "openconfig-network-instance"
path = "/network-instances/network-instance/protocols/protocol/bgp/neighbors/neighbor/state/"
subscription_mode = "sample"
sample_interval = "30s"
