Migration from 1.8.x to latest 2.x
I’m in the process of migrating all my data to influx 2 and i have run in to an issue.
Before i used QC to create min, max and mean daily data for all raw values.
this is the old QC:
CREATE CONTINUOUS QUERY daily_mean ON home
BEGIN SELECT mean(*) INTO home.longterm.hc_daily_mean
FROM home.raw.hc GROUP BY time(1d) END
i have converted it to:
option task = {
    every: 1d,
from(bucket: "raun3")
    |> range(start: -task.every)
    |> filter(fn: (r) => r._measurement == "hc")
    |> aggregateWindow(every: 1d, fn: mean)
    |> set(key: "_measurement", value: "hc_daily_mean")
    |> to(
        org: "svein",
        bucket: "raun3.longterm",
this works fine but the field names are not the same as they used to be.
in influx 1.8.x the names was prepended with the function name. so
“sensor_some_name”
was renamed to
“mean_sensor_some_name”
with the new flux task the field names are kept unchanged.
this causes a mismatch with all the old field names that i have from influx 1.8.x
so now i have
“mean_sensor_some_name” for all data before the update,
and
“sensor_some_name” for all the new data.
how can i prepend “mean_” for all the new data so it matches the old?
i managed to solve this by adding a map function
option task = {
    every: 1d,
from(bucket: "raun3.raw")
    |> map(fn: (r) => ({r with _field: "mean_" + r._field}))
    |> to(
        org: "svein",
Hello @svefro,
I actually recommend holding off on upgrading to 2.x. Instead I’d wait for 3.x OSS to release later this year.
It offers significant performance benefits and is centered around interoperability so you don’t have to learn Flux. Instead you can use InfluxQL and SQL with 3.x OSS.
InfluxDB 3.0 is up to 45x Faster for Recent Data Compared to InfluxDB Open…
In this post, we look at recent benchmarks comparing InfluxDB 3.0 to InfluxDB Open Source (OSS) 1.8. influxdb
Just fyi
