Migrated shards deleted 30 mins after starting influxdb
I’m busy testing the migration process from influx 1 to influx 2.
Version before upgrade: influxdb-1.12.2-3.x86_64
Version after upgrade: influxdb2-2.7.12-2.x86_64
Before migration I have a database with retention period 90 days called myowndata.
Relevant logs:
Migration copied data to: {“level”:“debug”,“ts”:1763645959.859166,“caller”:“upgrade/database.go:129”,“msg”:“Copying data”,“source”:“/var/lib/influxdb/data/myowndata/autogen”,“target”:“/var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen”}
{“level”:“debug”,“ts”:1763645960.0615513,“caller”:“upgrade/database.go:144”,“msg”:“Copying wal”,“source”:“/var/lib/influxdb/wal/myowndata/autogen”,“target”:“/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen”}
Migration log end:
{“level”:“info”,“ts”:1763645960.0618873,“caller”:“upgrade/database.go:195”,“msg”:“Database upgrade complete”,“upgraded_count”:2}
{“level”:“info”,“ts”:1763645960.0619164,“caller”:“upgrade/security.go:45”,“msg”:“Upgrading 1.x users”}
{“level”:“warn”,“ts”:1763645960.0619307,“caller”:“upgrade/security.go:50”,“msg”:“User is admin and will not be upgraded”,“username”:“ndewet”}
{“level”:“debug”,“ts”:1763645960.0619712,“caller”:“tenant/middleware_user_logging.go:49”,“msg”:“user find by ID”,“store”:“new”,“took”:0.000025285}
{“level”:“debug”,“ts”:1763645960.0619967,“caller”:“tenant/middleware_org_logging.go:48”,“msg”:“org find by ID”,“store”:“new”,“took”:0.000011586}
{“level”:“debug”,“ts”:1763645960.073645,“caller”:“upgrade/security.go:107”,“msg”:“User upgraded”,“username”:“telegraf”}
{“level”:“info”,“ts”:1763645960.0736895,“caller”:“upgrade/security.go:115”,“msg”:“User upgrade complete”,“upgraded_count”:1}
{“level”:“info”,“ts”:1763645960.0737052,“caller”:“upgrade/upgrade.go:488”,“msg”:“Upgrade successfully completed. Start the influxd service now, then log in”,“login_url”:“``http://localhost:8086``”}
V2 Engine startup reads from:
Nov 20 15:40:46 localhost influxd-systemd-start.sh[16275]: ts=2025-11-20T13:40:46.763397Z lvl=info msg=“Using data dir” log_id=0~KNmadG000 service=storage-engine service=store path=/var/lib/influxdb/engine/data
TSM files created during upgrade:
201327563 20672 -rw-r–r-- 1 influxdb influxdb 21167037 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/18/000000009-000000002.tsm
758107 20708 -rw-r–r-- 1 influxdb influxdb 21204362 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/19/000000009-000000002.tsm
67461582 20724 -rw-r–r-- 1 influxdb influxdb 21220185 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/20/000000009-000000002.tsm
135072339 20872 -rw-r–r-- 1 influxdb influxdb 21371102 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/21/000000009-000000002.tsm
201327567 20800 -rw-r–r-- 1 influxdb influxdb 21295731 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/22/000000009-000000002.tsm
758110 20784 -rw-r–r-- 1 influxdb influxdb 21281861 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/23/000000010-000000002.tsm
67461585 20784 -rw-r–r-- 1 influxdb influxdb 21280484 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/24/000000009-000000002.tsm
135072342 21020 -rw-r–r-- 1 influxdb influxdb 21522374 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/25/000000009-000000002.tsm
201327570 21020 -rw-r–r-- 1 influxdb influxdb 21520837 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/26/000000011-000000002.tsm
758113 18868 -rw-r–r-- 1 influxdb influxdb 19320716 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/27/000000010-000000002.tsm
67461588 20504 -rw-r–r-- 1 influxdb influxdb 20992814 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/28/000000009-000000002.tsm
135072345 21224 -rw-r–r-- 1 influxdb influxdb 21729577 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/29/000000010-000000002.tsm
201327575 21444 -rw-r–r-- 1 influxdb influxdb 21958196 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/30/000000009-000000002.tsm
758116 2612 -rw-r–r-- 1 influxdb influxdb 2672142 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/31/000000001-000000001.tsm
758117 2604 -rw-r–r-- 1 influxdb influxdb 2663576 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/31/000000002-000000001.tsm
758118 2600 -rw-r–r-- 1 influxdb influxdb 2661920 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/31/000000003-000000001.tsm
758119 32 -rw-r–r-- 1 influxdb influxdb 31733 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/31/000000004-000000001.tsm
758120 100 -rw-r–r-- 1 influxdb influxdb 99745 Nov 20 15:39 /var/lib/influxdb/engine/data/dbbedf296e09ccb1/autogen/31/000000005-000000001.tsm
WAL folders creating during upgrade (unfortunately I dont have full listing):
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/18
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/19
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/20
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/21
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/22
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/23
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/24
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/25
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/26
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/27
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/28
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/29
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/30
/var/lib/influxdb/engine/wal/dbbedf296e09ccb1/autogen/31
The upgrade process appears to complete successfully, as I can see my data in both influxv2 UI and choronograf connected to influxv2.
After 30 minutes of running, I see this in the logs:
Nov 20 16:10:47 localhost influxd-systemd-start.sh[16275]: ts=2025-11-20T14:10:47.889426Z lvl=info msg=“Deleting expired shard group (start)” log_id=0~KNmadG000 service=retention op_name=retention_delete_check op_name=retention_delete_expired_shard_group db_instance=dbbedf296e09ccb1 db_shard_group=2 db_rp=autogen op_event=start
Nov 20 16:10:47 localhost influxd-systemd-start.sh[16275]: ts=2025-11-20T14:10:47.894079Z lvl=info msg=“Deleted shard group” log_id=0~KNmadG000 service=retention op_name=retention_delete_check op_name=retention_delete_expired_shard_group db_instance=dbbedf296e09ccb1 db_shard_group=2 db_rp=autogen
Nov 20 16:10:47 localhost influxd-systemd-start.sh[16275]: ts=2025-11-20T14:10:47.894101Z lvl=info msg=“Group’s shards will be removed from local storage if found” log_id=0~KNmadG000 service=retention op_name=retention_delete_check op_name=retention_delete_expired_shard_group db_instance=dbbedf296e09ccb1 db_shard_group=2 db_rp=autogen shards=0,3
Nov 20 16:10:47 localhost influxd-systemd-start.sh[16275]: ts=2025-11-20T14:10:47.894108Z lvl=info msg=“Deleting expired shard group (end)” log_id=0~KNmadG000 service=retention op_name=retention_delete_check op_name=retention_delete_expired_shard_group db_instance=dbbedf296e09ccb1 db_shard_group=2 db_rp=autogen op_event=end op_elapsed=4.685ms
Output of influx bucket list:
ID Name Retention Shard group duration Organization ID Schema Type
6aeaee131cce724c _monitoring 168h0m0s 24h0m0s 6ff68fa7b44da352 implicit
72bb6f939da448e0 _tasks 72h0m0s 24h0m0s 6ff68fa7b44da352 implicit
2277a5667194434f default infinite 168h0m0s 6ff68fa7b44da352 implicit
dbbedf296e09ccb1 myowndata/autogen 2160h0m0s 168h0m0s 6ff68fa7b44da352 implicit
b4086d5b3683d537 telegraf/autogen infinite 168h0m0s 6ff68fa7b44da352 implicit
The data I could see in both chronograf and influxv2 ui is for 19 November 2025, so should not have been removed, but all the data has been deleted.
This is a repeatable process, as I’m using a vm that I can just roll back to the v1 state and repeat the process.
I would really appreciate any input or pointers as to what to check next, as I cannot have data disappearing when doing the upgrade in production.
From reading a few other relateec threads the advice seems to be to stay on v1.
Staying on V1 is certainly a fine option. 1.12.2 is slightly ahead of 2.7.12 in terms of bug fixes (i.e., the work was done in 1.X and has yet to be ported to 2.X, though that will happen early in 2026), and if you have a working 1.12 installation, staying with that is fine.
If you do prefer to move to 2.X, then to debug this, do a SHOW SHARDS in 1.X to check all the expiration dates of your data and look for any anomalies there, as a start.
I’m busy rerunning the process, this is the output of SHOW SHARDS for the db in question:
The expiry_time looks correct according to the retention period of 90d. What else should I look for?
After letting v1 run for a while, the 1st shard has been discarded, as expected.
If you upgrade again, halt the v2 instance before.you see retention enforcement. Then look at the boltdb with one of the common free bolt viewers and examine the shard and shard group information. Can supply more details if the above is not clear to you.
Thanks, will try it.
I can see this list of objects:
opening up bucketsv1 shows this related to the migrated database:
90 day retention, 7 day shards looks correct, doesn’t it?
When you start up V2 after the migration, run a SHOW SHARDS immediately, then after the retention service runs, if you would, and we can see exactly what was inappropriately discarded, if anything.
SHOW SHARDS is not a command in V2. Found suggestion to use this query, but it yields no results.
Found these in the metrics endpoint.
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="20",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/20",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/20"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="21",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/21",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/21"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="22",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/22",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/22"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="23",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/23",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/23"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="24",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/24",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/24"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="25",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/25",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/25"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="26",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/26",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/26"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="27",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/27",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/27"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="28",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/28",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/28"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="29",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/29",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/29"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="30",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/30",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/30"} 0
storage_shard_disk_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="31",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/31",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/31"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="20",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/20",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/20"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="21",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/21",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/21"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="22",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/22",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/22"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="23",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/23",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/23"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="24",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/24",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/24"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="25",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/25",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/25"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="26",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/26",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/26"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="27",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/27",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/27"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="28",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/28",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/28"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="29",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/29",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/29"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="30",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/30",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/30"} 0
storage_shard_fields_created{bucket="4282f048f7a8f8b2",engine="tsm1",id="31",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/31",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/31"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="20",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/20",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/20"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="21",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/21",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/21"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="22",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/22",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/22"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="23",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/23",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/23"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="24",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/24",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/24"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="25",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/25",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/25"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="26",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/26",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/26"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="27",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/27",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/27"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="28",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/28",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/28"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="29",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/29",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/29"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="30",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/30",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/30"} 0
storage_shard_series{bucket="4282f048f7a8f8b2",engine="tsm1",id="31",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/31",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/31"} 0
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="20",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/20",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/20"} 2.1220185e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="21",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/21",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/21"} 2.1371102e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="22",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/22",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/22"} 2.1295731e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="23",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/23",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/23"} 2.1281861e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="24",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/24",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/24"} 2.1280484e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="25",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/25",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/25"} 2.1522374e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="26",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/26",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/26"} 2.1520837e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="27",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/27",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/27"} 1.9320716e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="28",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/28",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/28"} 2.0992814e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="29",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/29",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/29"} 2.1729577e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="30",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/30",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/30"} 2.1958196e+07
storage_tsm_files_disk_bytes{bucket="4282f048f7a8f8b2",engine="tsm1",id="31",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/31",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/31"} 8.016441e+06
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="20",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/20",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/20"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="21",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/21",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/21"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="22",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/22",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/22"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="23",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/23",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/23"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="24",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/24",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/24"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="25",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/25",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/25"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="26",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/26",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/26"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="27",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/27",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/27"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="28",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/28",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/28"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="29",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/29",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/29"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="30",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/30",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/30"} 1
storage_tsm_files_total{bucket="4282f048f7a8f8b2",engine="tsm1",id="31",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/31",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/31"} 1
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="20",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/20",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/20"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="21",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/21",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/21"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="22",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/22",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/22"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="23",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/23",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/23"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="24",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/24",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/24"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="25",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/25",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/25"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="26",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/26",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/26"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="27",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/27",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/27"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="28",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/28",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/28"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="29",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/29",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/29"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="30",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/30",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/30"} 0
storage_wal_size{bucket="4282f048f7a8f8b2",engine="tsm1",id="31",path="/var/lib/influxdb/engine/data/4282f048f7a8f8b2/autogen/31",walPath="/var/lib/influxdb/engine/wal/4282f048f7a8f8b2/autogen/31"} 0
The data is in the database:
Do the shards in V2 look like they have the right time ranges when you run influxd report-tsm on the bucket?
Looks correct to me (the db/bucket with id ending in f8b2 is the one I’m interested in):
