measurementTagValues with v.timeRangeStart, v.timeRangeStop
what is a proper way (fastest solution) to define variable in settings that will contain unique tag values of measurement,
in range v.timeRangeStart, v.timeRangeStop
used
import "experimental/array"
routePatterns = schema.measurementTagValues(
  bucket: v.bucket,
  measurement: "user_timing",
  tag: "path",
  start: v.timeRangeStart,
  stop: v.timeRangeStop,
allStream = array.from(rows: [{_value: "All"}])
filteredRoutePatternsWithAll = union(tables: [allStream, routePatterns])
under InfluxDB OSS 2.7
Expected behavior, when I change timeRange in dashboard to have only tag values from this range (plus custom “All” value)
I am correctly understand that measurementTagValues couldnt work v.timeRangeStart, v.timeRangeStop?
Hello @va2dim,
schema.measurementTagValues() doesn’t support the v.timeRangeStart and v.timeRangeStop parameters in the way you expect because it retrieves all unique tag values across the entire measurement, not just within a specific time range.
Try this:
// Filter the measurement by the time range and then extract unique tag values for the tag "path"
routePatterns = from(bucket: v.bucket)
  |> filter(fn: (r) => r._measurement == "user_timing")
  |> keep(columns: ["path"]) // Keep only the tag column
  |> group() // Group the data to eliminate duplicates
  |> distinct(column: "path") // Get unique tag values
// Add "All" value manually
// Combine "All" with the distinct tag values
Thanks @Anaisdg ,
I need (array) routePatterns not only as dashboard variable v.path (to filter my dataset), but also
in my query to use it for array.map purpose (for option “All”).
I am interesting in some way to extract list/array of all possible option of this dashboard variable (to not duplicate & execute same logic twice). Please guide, exist some possibility to do this?
