Does influx db have a maximum database size? I’ve started using influx as a pilot and its started to get traction and now im worried about the database crashing or slowing down. Any help appreciated.
This can be a complex question. The database doesn’t have a maximum size. The performance of the database can be limited by hardware or the schema, depending on your situation.
Take a look at the hardware sizing guidelines and the encouraged schema design.
