I’m quite new using influxdb and SQL like language in general.
I am collecting some power measurements from some zigbee smart plugs and NodeRed stores them in influx.
Now I would like “convert” those measures in watt to Kwh.
First of all I thought to use mean
function to calculate the mean of the measures grouping them by a specific interval:
> select mean(*) from power.autogen.frigorifero where time> now()-24h group by time(1h) fill(0)
time mean_value
1553709600000000000 149.50197628458497
1553713200000000000 30.153361344537814
1553716800000000000 143.65522388059702
1553720400000000000 120.80924287118977
1553724000000000000 128.0880149812734
1553727600000000000 70.65906210392902
1553731200000000000 118.14522821576763
1553734800000000000 92.06942392909896
1553738400000000000 41.93884892086331
1553742000000000000 107.48995363214837
1553745600000000000 8.712121212121213
1553749200000000000 117.536
1553752800000000000 63.27383367139959
1553756400000000000 126.72920696324951
1553760000000000000 243.04273504273505
1553763600000000000 144.0154711673699
1553767200000000000 43.862385321100916
1553770800000000000 116.73634945397816
1553774400000000000 8.378787878787879
1553778000000000000 135.23595505617976
1553781600000000000 58.214920071047956
1553785200000000000 114.91379310344827
1553788800000000000 69.89889196675901
1553792400000000000 86.96193771626298
1553796000000000000 0.9857142857142858
Now I should multiply each value for a time period and then sum all those values but as I read in the Influx common issues I cannot do something like:
select mean(*) * 1 from power.autogen.frigorifero where time> now()-24h group by time(1h) fill(0)
Is there any smart way to convert my measures from W to Wh?
Thank You
Regards
